Serious stumbling on the gas.. Is this a MAF?
Hi all.
Motor is warm, powering onto an onramp, second gear goes
well at most-throttle, but on changing up to third, gassing
it just gets a bogging hesitation as if the fuel was cut off.
Lifting the throttle to a cruise amount, and the car runs
OK. There's over half a tank of gas, and I was going straight
so no chance of gas sloshing away from the pickup...
thanks,
Joe
thanks,
Joe
any lights flashing while you're on it? Put it in 3rd gear at low rpms going about 35-40mph and then floor it.... if you get to 4.5Krpms and it starts to hesitate/buck then it's your plugs Joe.
Ok, two more runs. I turned off PSM just in case. Hard second-to-third
got a serious stuttering and a little backfire on the gas in third. A hard
pull from low RPM in third resulted in it simply plateauing, holding at
about 4000 RPM with the gas floored...
Joe
Joe
