PCCB worth ordering or not?
Originally posted by acw
Interesting... I'll try to change pads.
AW
AW
Originally posted by Joe Weinstein
Those brakes affect handling and acceleration because they're
lighter, but that will mostly have *zero* effect on typical braking.
"wet or dry' talk is silly. Every porsche in the last 40 years has
had brakes strong enought o lock up the tires at any speed, so
more brakes means nothing. The limiting factor is tire traction.
That being said, *I* would have ordered them for the lightness,
if they were available when I bought my car.
Joe
Joe
have you tried them? properly bedded they bite harder and are much better in the rain as they bite thru the wet adn steel do not, steel needs to dry the rotor first.
Arnaud,
if your pads are "glazed" they wont bite cold or wet. heavy multiple brakings speed to 5 mph may clear it up, or new pads needed.
additional nicety for us wheelwaxers, your wheels are clean all the time, no black dust.
i have 16,000 miles on 3 Gt2's now with no issues, but i would not order them as an option, as heavy track use has caused problems. schatz motorsports has factory rebuilds for 1/2 new, but they are still $$$ if you ruin them.
Originally posted by watt
Joe,
Joe,
essentially a flat surface) is going to push water away any
quicker than another. If there is a difference in the number of
holes in the disks, that provide extra places for water to be
pushed into, then that might make a difference, but water
is incompressible, and if it is between the pad and rotor, it
doesn't make any difference what material they are made of,
the water has to be physically squeezed away before there
is any friction between pad and rotor.
Joe
Chris Green@USP
996 Turbo Vendor Classifieds
08-20-2015 11:30 AM
turbosonoma
08-19-2015 02:05 PM
