GT700 options for more horsepower?
#62
Originally Posted by MARKSKI
Craig,
Rob has everything except the turbos, ecu and fuel system.
Craig
#63
My comment is even off the shelf kits are not truely, things change from day to day, maf screens, all sorts of other things. Craig how long and how many times have you been under the knife? Same goes for Joe (NY) not the world fastest. These kits are not shelf anyway you cut it! If you are goin to go custom custom promotive is the answer I feel. No one else is even close to date. I am not bashing EVO, but it depends on the end result wanted? If you piece it together that will just create the world largest nightmare!
#64
#66
Originally Posted by joetwint
Well I disagree,the fastest cars on here are within 1mph of each other in the 1/4..an Evoms car (690rwhp)and a Proto car(871rwhp),and .4 tenths seperate the two in both 60-130 and 1/4.....The .4 tenth difference in the 60-130 could possibly be attributed that Mark was running at a 2.7% downgrade and the Evoms car was run at a .6% downgrade. Just the facts and no disrespect to anyone.Not to mention if you think that Evo off the shelf kit is high I can only imagine what it would cost to duplicate Mark's beast.Oh and no I am not the worlds fastest but my car is not stripped(as everyone has seen)and was still running AWD at the time on a drag radial tire...not M+H street slick(big difference).My point is ,I believe the best bang for the buck are the 700 kits whether Proto,Evo,Umw,because after that it starts getting real expensive to get these cars to run much faster.These cars won't handle 35 lbs of boost(like a Supra)nor are the motors big enough to produce the power of the Vipers.
#67
Mark,Doesn't he need to do the bottom end and heads?
Either way, the gt30rs are superior to the gt35rs for 1/4. u get full boost at least 1500 rpms sooner and u get a lot more Torque becasue ur A/R housing is smaller and u run more boost.... and boost produces TQ. And it's TQ that gets you down the track.... So you guys have a good set up no doubt about it.
mark
2001 996TT 3.6L and stock ECU
#68
Craig
#69
700 == best bang for the buck!
The one thing I go agree with is the best bang for the buck is the 700 kits.
EVOMs has a great one, the UMW "looks good" (havent seen it perform yet) and I believe the one I am doing should perform pretty well also .
After all I did have to sigh a waiver that my car will be capable of 200mph and my tuner is not responsible for my behavior.
Marty K.
Marty K.
#70
I also agree that the GT700 kit is the optimal tuning package (along with the corresponding 700 HP packages from Proto and UMW). Beyond 700 HP, the returns diminish considerably.
Craig
#71
Marty K.
Marty K.
I think you are getting the optimal amount of power Marty!!!
Craig
#72
He has the bottom end done. Heads? Im not sure but last time I checked the gt800s didnt come with headwork. thats was extra... I recall that Todd Z said somewhere online( or someone associated with him) that when his car ran the 10.3 it was/is a base gt800 without heads or cams and only rods with apr studs.
mark
mark
#73
not to get off topic, but if i remember from the thread about markski's 10.037, that run was at "1.24 bar w/ misfire at 6k"? if markski's car produces 871rwhp @ 1.5 bar, @ 1.24 bar it is no doubt producing less than 871rwhp. from his dyno thread, his car produced 733rwhp @ 16psi. 1.24 bar is around the neighborhood of 18psi. i think the 10.0 @ 144 wasn't at max power? also, in the Modified Luxury & Exotics article about the "EVO GTONE," the writer states that the EVO car on 116 octane produces 890 horsepower at the wheels. they say 752hp on 93 octane, but do not say if this is at the wheels or at the crank. i would think that they would be consistent, and this figure is measured at the wheels, just as the 890hp figure is. the magazine also states its quarter mile time as 10.37 @ 139.68mph, but does not specify how much power the car was producing during the run. it also doesn't say if the 10.37 run was made at the current power level...from the info i've seen, it seems the EVO car was making more than 690rwhp, and markski's car was producing less than 871rwhp at the times of their runs. so, i think that the difference b/t the cars' respective power levels during the times they ran the 1/4 mile probably isn't as big. regardless, AMAZING achievements!
#74
Originally Posted by Craig
This is getting down right scary . . . I am compelled to agree with you for a second time during less than a week span. What is this world coming to?
Craig
Craig
#75
Originally Posted by KompressorKev
not to get off topic, but if i remember from the thread about markski's 10.037, that run was at "1.24 bar w/ misfire at 6k"? if markski's car produces 871rwhp @ 1.5 bar, @ 1.24 bar it is no doubt producing less than 871rwhp. from his dyno thread, his car produced 733rwhp @ 16psi. 1.24 bar is around the neighborhood of 18psi. i think the 10.0 @ 144 wasn't at max power? also, in the Modified Luxury & Exotics article about the "EVO GTONE," the writer states that the EVO car on 116 octane produces 890 horsepower at the wheels. they say 752hp on 93 octane, but do not say if this is at the wheels or at the wheels, just as the 890hp figure is. i would think that they would be consistent, and this figure is measured at the crank. the magazine also states its quarter mile time as 10.37 @ 139.68mph, but does not specify how much power the car was producing during the run. it also doesn't say if the 10.37 run was made at the current power level...yet i think that the difference b/t the cars' respective power levels during the times they ran the 1/4 mile probably isn't that big. regardless, amazing achievements!
Thanks for bringing that up. I have always wondered about that article
Jag
