where do you put the jack stands?
Old 03-24-2004, 07:40 PM
john stephanus's Avatar
john stephanus is infamous around these parts
CR...You may want to re-think the short jack choice. I believe the max lift height is quite alot less than the longer one.
Old 03-24-2004, 07:49 PM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
Hmmm, Did I make a mistake for oil changes by getting the shorter jack? According to Rocketman's post it seemed like the shorter one would work fine. I would prefer the shorter version if it works, since it won't take up as much room. Otherwise, I will have to change the order ASAP. Thanks for the advise.
Old 03-24-2004, 08:22 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
No mistake...It lifts it plenty high...In fact the nose of the car will hit the pavement before you can even jack it up with half of the jack's lifting height capacity
Old 03-24-2004, 08:32 PM
Code Red's Avatar
That's a relief! Now I will be all set for tire and oil changes.
Old 03-24-2004, 08:43 PM
rockitman's Avatar
The jack stands are 13.5 inches with the pad at their lowest postion. You have about 1 or 2 more inches max you can raise the jackstands and place them under the main rear suspension truss without the nose/lip of the front hitting the garage floor, at least with the GT3... I believe the GT2 may even be 1 inch lower... The jack at maximum lift with the jack pad is 20.5 inches...I just went out to the garage to make the measurements. I use the stands at the standard height (minimum setting) and have plenty of room to get under the car to get at the drain plugs...
Old 03-24-2004, 09:02 PM
Code Red's Avatar
Is the main rear suspension strut obvious to the untrained eye?
Thanks again for all the info. This has been very helpful. I refuse to pay the dealer close to $300 for a simple oil change, plus I am going to put cups on the stock rims for use on track days anyway.
Old 03-24-2004, 09:12 PM
rockitman's Avatar
Yes, it looks like a construction I-Beam...You cant miss it. It's light bronze in color and looks to be the strongest part under the car...
You can see where I have them placed in this pic...
Another shot to show you the spread.
Old 03-24-2004, 09:37 PM
Code Red's Avatar
Ahh, so it's the portion where the sway bars go. Any pics of where you place the jack on the engine to raise the car?
I also need to find the thread of doing an oil change. I understand that there are two filters.
I feel like I am taking a correspondance course in auto mechanics.
Old 03-25-2004, 05:35 AM
rockitman's Avatar
The jack goes right under the center of the motor on the cranck case. Put the seam where the two halves of the engine crankcase meet at it's lowest point relative to the floor. Your crank case is the same as mine. Here is the DYI link for it. Order the parts by part number from suncoast porsche's parts dept. call them, since all the sealing rings ect are not listed.
http://www.renntech.org/forums/index...code=diy_oc_tt
here is the index link of DYI's from renntech
http://www.renntech.org/forums/index...&code=diy_menu
There is a picture of crankcase where you want the jack pad to go for lifting the back end of the car so you can put jack stands under the suspension truss. You can see it on the oil change DYI link.
Line the jack pad up under the seam below the drain plug that has an arrow pointing to it.
Old 03-25-2004, 09:20 AM
Code Red's Avatar
Thanks again Rocketman!
00aston
12-25-2015 11:11 AM
Tiago
09-14-2015 10:06 AM
WheelB
American Muscle
09-11-2015 09:49 AM
MC36
Southeast
09-01-2015 06:39 PM
Quick Reply: where do you put the jack stands?
