Coilover comparison thread
Suppose I've made up my mind to spend some bux to replace the factory parts (regular tt) with aftermarket coilovers. Digging through the archives turned up PSS9, JIC Cross, and KW. How have you guys decided which brand to go with? Each of the brands has its advocates in the archives, but I haven't found a thread that compares them.
Which of the 3 include a setting that's close to stock in terms of stiffness for street use? I drive this thing everyday and don't want my eyeballs rattling out on bad pavement.
TIA!
Jeff
TIA!
Jeff
Thanks for the relies thus far. I need to expand my list to:
PSS9
JIC Cross
KW
H&R
Gemballa (same as H&R?)
I'm wondering if all of these coilover options include at least one setting that is close to stock in terms of ride harshness.
And I'm still wondering how those of you who made the change decided which brand to go with.
Jeff
PSS9
JIC Cross
KW
H&R
Jeff
I did PSS9's and I like the ride for the street. You can't go quite as low with them as JIC/Cross, but if you are looking for close to stock ride feel (only slightly stiffer) and lower stance they are good. It's low enough that I sometimes scrape the front lip on my driveway, so I don't think I could have gone much lower anyway even if I had more aggressive suspension.
I was originally considering PSS9s but I didnt like the height restrictions. I ended up going with JIC's and have them set to the softest settings (with the purple springs). The ride is a bit firmer than stock, but its still very comfortable. Handling is much improved.
What amazes is the concept of the handling getting better than it is now. I had the car on highways 9 and 236 in the Santa Cruz mountains last Saturday. It's already a lot more fun than my Z51 + Bilstein + Mich PS2 + Magnacharger C5 in the twisties.
Jeff
With the stock suspension, the car felt "floaty" at high speeds and it was very disconcerting. With the JIC's, it feels planted on the ground at all times and also corners with less sway. On bad roads, the ride is definitely more rough than stock, but on highways and regular streets, it's quite comfortable. The only time I've had passengers make any comments is when I'm driving over a rough patch of road.
Originally Posted by AL Z
AG996LV, can the PSS9 be adjusted to be softer then stock. Thanks..AL Z
