Very Smelly AC!
Very Smelly AC!
My AC system has been emitting a really foul mildew smell when first turned on lately. The dealer has changed the cabin filter twice and has sprayed some kind of spray into the system twice as well.
The smell greatly diminished for a week or two, but is yet again back. Has anyone dealt with this before? Any ideas, tips, or fixes?
Thanks!
Rob
Thanks!
Rob
Originally Posted by cab2u
When I had a really bad smell in my last 911, I found that mice had made a home for themselves in the pollen filter (under the front hood near the passenger side).
Ok....Mice.....Hanta Virus... ???? Now I'm concerned! hahaha
I would hope that the dealer would have seen rodents in the two times they have "addressed" this issue for me. I am going to try the heat method and cross my fingers. If that doesn't work, it's off to the dealer again. Oh what fun!
Thanks for your input guys...I'll keep you posted.
Rob
Rob
I used a charcoal cabin filter, and it worked great. Areas such as Florida (where I live) with high humidity are probably worse.
Also, get underneath your dash on the passenger footwell and remove a plastic linining with two simple plastic screws. Look towards the condensor. It may be that its about to go (happened to me) and tons of mildew growth on it.
Originally Posted by OneFasTT996
A friend of my family had that happen and the mice had the Hanta Virus. When they got in the car and ran the AC they got a large dose and died within days. Still freaks me out.
Back to topic...try spraying Lysol in to the a/c intake (with the filter removed, heat and a/c on. It will come back every once in a while and you will have to repeat the Lysol treatment.
To avoid the mildew smell in the A/C, turn the compressor off and run the fan on high (lower temp.) to reduce condensation in the ducts/ evaporator. This should be done approx. 20 sec. or so every time you use the a/c.
Originally Posted by roadsterdoc
That's horrible. Years ago I saw a young Marine that had contracted the Hanta virus. He had just returned from training in Korea. Rodents left droppings in his tent under his rack. He had a light case and survived, but it was still awful. Aerosolized droppings is exactly how this virus is contracted by humans. Even if the doctors knew what it was initially, and that would be unlikely, it was probably still too late to save them given the direct blast in the face from the a/c. Where did they live?
Rob
Rob
Bake it out, like sumone mentioned, crank the heater, then air out the cabin and spray Lysol or =. Be sure to run the A/C for a good ten minutes or so monthly, even if it is winter. Also like sumone mentioned, turn off the compressor (leaving the fan running)a few minutes prior to shutting down the car, gets rid of condensation.
GL
GL
I doubt you have any chance of getting that virus. I was talking more to the guy who found the mice living in there. That being said, if you put your car away for the winter it's always good to make sure you don't have any critters living in your car ;-)
Sorry for OT!
Originally Posted by Gusagain
Hantavirus is going around over here too lately. And to make matters worse, the mouse that is thought to be carrying it over here is a protected species - ???? Officials have to "relocate" the mouse instead of killing the little varment. yea wtf?
Sorry for OT!
Sorry for OT!
harvest
09-30-2015 11:42 AM
