Issues with lightweight flywheel....
I have put a lightweight flywheel and new racing clutch on my car and have some issues. In the past week the car has stalled about 10 times when I depress the clutch. Also, while idling with the clutch depressed if I sligthly blip the throttle up to 1800 rpm the engine almost always dies.
Does anybody else have these problems? In fact, of you 600hp and up guys, how many of you went to a ligthweight flywheel vs the stock heavier one? Do any of you higher-hp guys think, or have been told, there are any issues in staying with the stock flywheel as far as it breaking?
-- Michael
-- Michael
I have the lightweight flywheel and Stage 2 Clutch. I have had some stalling issues with the car but only after getting on the car hard, then coming to a stop.
My only dig with the flywheel is the sound of it with the clutch depressed. Sounds like a throw out bearing that went through hell. Other than that much better and quicker revs.
i have that problem all the time... and i learned...hahaha
when u come to a stop light... try to let the engine rpm drop down first... then depress the clutch... when it's around 2000rpm...
that should solve the problem...^_^
Originally posted by MKW
It's an ECU programming problem. The computer isn't programmed to respond to the rapid rev drop of a lightened flywheel between shifts or esp going to idle .
My noises with the lightweight flywheel are under the following conditions:
1) At a stop if I am in nuetral and I let out the clutch. The sound is almost embarassing if I am around other cars, it sounds like something it loose on the car. So, now I spend a lot more time just holding the clutch in at a stop light, not sure how bad this is.
2) Any time the car lugs. I.E. I short shift and the rpms' are around 2k, if I give it gas the flywheel will make an awful loud noise.
The other problem is that my starts in 1st are real jerky, the dual-mass really is forgiving and makes you feel like a pro, I feel like I barely know how to drive a manual transmission with the lightweight, but I suspect this is just a learning curve.
My Ferrari 360 comes from the factory with a light flywheel, but it makes none of the noises of this one, any idea why?
-- Michael
-- Michael
-- Michael
What is your opinion..........
I am getting the GT/R hardware installed early next week. I was also planning on having the dealership install a performance clutch & lightweight flywheel @ the same time.
Q. Should I forget about the lightweight flywheel and just do the clutch?
or
have the noisey, hard to use flywheel which is prone to making the car stall installed also????????
Mike
or
Mike
adnanm3
11-22-2023 02:43 AM
