how much power/torque can the standard block and rods take?
This becomes a difficult and touchy subject.
We know that Alois does do a motor tear down for his 590 Nardo kit and
above and who could argue other than the fact that there are quite a few
higher powered cars now running around on stock internals (Mine will soon be
one of them). It was a financial decision for me as it is for others, tearing into the motor costs roughly $15k US (and up, depending on what you do once inside), ironically this is the exact cost to replace an entire motor as
displayed by Cpu77 recently. Time will tell and also if us "high powered,
stock internal folks" use our boost and high octane wisely...this can make a huge differnce. I for one will be running lower boost than some of the Kaboom crowd. I would think (I am no expert) that your set-up should be
a great one and as long as prudence is used, your GT2 will have a long and
happy life.
Marty
happy life.
Marty
Originally Posted by ukgt2
Hi all
Im just trying to do a bit of homework prior to getting my car mapped.
The Gt2 has been undergoing some mods of late such as;
DonG's intake plenum (excellent peice of kit by the way don )
75mm throttle body with rss intake plenum
K24/26 hybrids
Upgraded k24 headers, the new style ones like piero's
5 bar fpr
B&M filter
billet dv's
In addition to the milltek exhaust i allready had.
Thing im looking to know is how much Bhp/ Torque can the bottom end reliably run,
We can get up to 99ron pump gas here which ive heard is the same as your guys 93 but im not sure about this.
Any advise would be appreciated guys.
K24/26 hybrids
5 bar fpr
B&M filter
billet dv's
99RON is the equivalent of 94MON (american standard) i believe alot of the racing fuel over in states is 100+, which would be a very high ron rating....
Also think, VERY seriously about where you would have the car mapped....unless you fancy having silly torque numbers...
I think you're good to at least 700 crank. 600 is well below that. I run something close to 600 with minor bolt-ons and primarily 91 octane, Unless I know I'm going to the track, then I run 101 just to be safe under extended load.
Only RUF recommends a rebuild at 690 HP and they are notoriously conservative.
Craig had posted a good thread a while back regarding not using more octane than is necessary because it has tendency to fill your engine with carbon (unburned fuel) due to the higher and slower flash point and burn.
proTUNING Freaks
09-15-2015 07:28 AM
albert@velosdesignwerks
997 Turbo Vendor Classifieds
09-11-2015 07:59 PM
GT3/GT2/GT Vendor Classifieds
09-11-2015 07:54 PM
991 Turbo Vendor Classifieds
09-11-2015 07:39 PM
