Clutch Pedal Gritty - Slave Issue?
Old 11-29-2007, 06:23 PM
tjj7ff's Avatar
tjj7ff is infamous around these parts
I had this problem and ended up having the master and accumulator. This was after hydraulic fluid exploded out of the clutch reservoir when it failed. After these were replaced I noticed the gritty feeling clutch pedal getting worst over time. It ended up being grit that had accumulated over time in the clutch tube. It required dropping the transmission to clean the tube. The Porsche tech was able to do this without having to drop the entire engine and transmission. He said the grit came from disk wear similar to what we see from brake pads. Every since this was done the clutch peddle is very smooth and easy to apply.
Old 07-11-2008, 07:57 AM
DRMitchell's Avatar
DRMitchell is infamous around these parts
My clutch some time feels gritty at the bottom, but is not slipping. Anyone know if master/slave issue is a warranty item (esp. after market warranty) or is it considered a wear item, along with the clutch?
Thanks,
Doug
Old 07-11-2008, 10:18 AM
rwilliamtaylor's Avatar
rwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of light
Originally Posted by sharkster
We've replaced those as well once in a well. do ou have any fluid seeping out from the front filler/resevoir?
Mine just started seeping from the resevoir. What is the cause? Clutch feels normal.
SharkyShark20
09-19-2015 09:54 PM
orbelo
08-30-2015 12:26 PM
magoochi
08-23-2015 05:54 PM
cerbomark
08-22-2015 12:50 PM
Quick Reply: Clutch Pedal Gritty - Slave Issue?
