EVOMS 9.67 @ 149.86 - The Video -- Language Advisory - Sorry
#271
Originally Posted by robmd99
I think Mark's 1/8 time and speed was better? Now that is a new topic for all of you... enjoy
Robert
Robert
#273
Originally Posted by TRK
Hey,
Boy, we go on vacation for a week and come back to something exciting Congrats on a great run. First RECORDED 9 sec pass Sure, there's been a lot of talk about 9 second runs, but no proof, till now... It's great that you guys were able to take the time to put together your shop car and go to the extra length to get this run. I'm sure we all could get some amazing times if we weren't so busy building clients cars.
ToddZ,
Your axles are definitely proving themselves. We've spun off the outboard stubs of the stock axles a few times and have been reluctant to run yours because of that fact. that's why we had the whole axle built. Shoot out a set of them, we'll see how they work in Markski's car... I get a feeling that the axles we have in there now won't make it more than one or two runs like all the rest. It's been extremely frustrating and very difficult to get a good time when you're walking on eggshells all the time
I'm assuming you're only warrantying the parts you supply though. If we break the outboard stubs, you'll not warranty that part of the axle because you haven't supplied it, correct???
Congrats again on a superb run
ToddZ,
Edit: Since clarified in a later post.
#274
Originally Posted by MARKSKI
Joe, I have been told over time... and maybe some of the more experienced 1/4 guys can chime in... that for every 100 lbs u loose, one gains .1 seconds in ET. can anyone varify this?
BTW, Im not taking anything away from Evoms... If I could I probably would do the saem thing.
mark
mark
Even more importantly, the less weight the less **** you break on a hard launch.
For what it's worth there haven't been any hard launches yet. The 1.59 short from EVOMS is the best I've seen and that is soft for a car with that much power. If I can crack a 1.7x short time in a factory stock car then surely the big dogs can pop a 1.3x with 15" wheels, slicks and some suspension tweaks.
Anyone who is serious about taking the ET title; forget about making more power. Get the widest and tallest slicks under the car and set it up to launch hard without breaking. You will clobber a 1.59x short time and therefore storm the ET title.
#276
Originally Posted by sharkster
We sadly won't know because they had the timeslip witheld when they were booted out It'd be hard to have a better time through the 1/8th and then a slower one in the 1/4 unless that car was sand bagging Doesn't work that way. To get 150 you have to be moving fast as heck through the 1/8th...
#278
The thing is no one here wants to turn there car into a drag only vehicle. Running fast times in the 1/4 is just a fun side benefit of these beasts, which are clearly not designed to run fast down the strip.
Congrats again to Evoms!
#279
An enthuthiast should define his/hers priorities, in USA there is a lot of light to light racing (drag) almost all the time, Porsches are good in all of them,(drag/road) but not excellent, if you want to exel in either one you have to commit to whatever is your tune, they can go very fast down the strip, but you will have to commit ($$$$)for it as simple as that, same thing applies on the other side of the spectrum.
#280
Scott you don't need to explain yourself at all. I'd expect nothing less from you. A 9s a nine anyway you look at it and it doesn't matter how you get there. RWD, AWD, driving naked, 6speed, Tiptronic, snowing, raining, sunshine, cage, no cage, light weight seats, no seats.... Now go run your 9
#281
Keep pushing the Envelope
Robert
#282
Originally Posted by WOODTSTER
And please stop with the "Street Driven" Porsche stuff. The Silver Evoms
car has no airconditioning in it is probably
#283
I just think it's all about how far one is willing to go... thus with that said....
one needs to remove some things that normally are not that easy to put back... Like AC, power steering, abs, etc... and its not, I have been told, as easy as just removing the AC compressor... you still have to deal with the belt issue etc. I really do not think its for everyone.,... I really do not think 99% of will ever go this route. Most of us need directions for changing sparkplugs let alone hacking up the car and removing some serious weight.
To get our car below 3000 lbs we need to take out a lot more then just the 50 lbs AC compressor... brakes and Wheels are a huge handicap if you stay stock- but to upgrade these its in the thousands of dollars.... who is willing to fork out $3K just for drag rims?
the bottom line is that HP alone will not get you 9s...
markski
markski
2001 996TT 3.6L and stock ECU
#284
markski
markski
I don't know where you got that price from. Those wheels were less than $900. I'm the one who introduced EVOMS to the manufacturer. I've got a set for my Dodge that are 15x14, they only cost me $700.
#285
Originally Posted by RennTechV12
$3k?
The fronts were somewhere around $700 each and rears somewhere around $800 each I believe. If a set is $700 then Im on them NOW.
markski
