How many of you rev-match on the street?
#31
I do it almost everytime I drive the more I think about it. After I get on it I always blip the throttle in neutral, habit due to having cars with big cams (to make sure the car does not die).
#32
I always do it.. just a habbit....
2001 996TT 3.6L and stock ECU
#36
Originally Posted by arr0gant
If you mean Heel/Toe, I'm still learning.
#38
Originally Posted by Divexxtreme
"Rev-matching" is simply blipping the throttle while downshifting to prevent the "shock" effect that can shift your vehicle's weight and cause you to lose control. "Heel-toe" is just the common & proper way of doing it.
#41
Yup, it makes the drive funner and smoother... depends how I'm feeling though and how fast I'm going.
When I wanna show off I blip the throttle about 3 times then the last time match the rev and take off
#42
#44
Originally Posted by ashokn225
Scott, if you dont double clutch, can you burn through the clutch pretty easily?
#45
Thanks! For further clarification, when downshifting (but not turning) I should heel-toe when braking -> blip the throttle -> downshift to lower-gear (thus matching rev with tranny -> continue to break -> repeat again till down to 1st-gear then stop?
