How many of you rev-match on the street?
#62
Originally Posted by ashokn225
I usually use my clutch to slow down. I thought this thread was about downshifting to slow down, not to speed up. My bad.
If you are coming to a complete stop, just use the brakes. Downshifting is not needed at that point (unless you are timing for a green light...but you usually dont want to be the first guy shooting through the intersection anyways).
#63
Originally Posted by Ag Surfer
No offense to anyone but I find it funny that we are discussing this topic. How else would you downshift??? Sloooowly release the clutch as you shift from third to second? The whole reason you downshifted to begin with was, presumably, you needed more power.
#64
Originally Posted by Divexxtreme
You might do what 99% of other American drivers do. Downshift without blipping the throttle (i.e., rev-matching). Hence...why I asked.
#65
Double-clutching was used to prevent damage mostly to your trannny gears, not your clutch. And these days with the advent of tranny synchros, there's no point in double-clutching, IMO. That is...unless you drive a big-rig.
#66
No worries. But sincerely, you should use your brakes to slow down. Using the friction on the clutch disk is very inefficient as well as costly over time (clutch wear). If you want engine braking to have some control (coming down a long hill), by all means, blip the throttle, rev-match and get in that lower gear, but dont just ease the clutch out without rev-matching.
#67
Ok, question for you single clutch rev-matchers... I find that when I double clutch and am letting the clutch out on the final step to engage the lower gear I can get off it real fast because of the blip. However when I single clutch rev-match I feel myself having to take longer to disengage through the sweet spot because I'm doing a combination of blip and clutch work. I understand that this may be due to inexperience but my question is that of technique.
So do you clutch in > drop a gear > rev/blip while clutch is moving off point of engagement OR do you clutch in > drop a gear > rev/blip > get off the clutch? And I realize you can combine steps as in dropping a gear and blipping simultaneously. When I double clutch I do the latter, almost dumping the clutch when I am finally getting off because I don't need to "equalize" clutch and throttle, but when I single clutch I am doing much more disengaging the clutch while blipping the throttle.
Just curious. I know it's hard to interpret this but I hope some know what I mean. And the better you are the less you probably even notice the order of things.
#68
tw
#69
To break down what I meant... When you upshift you have to smooth out the shift by equalizing the clutch and the throttle, so do you do the same thing when you downshift AFTER you blip or do you just blip and let the clutch out and it should be smooth?
#70
The only reason to heel toe is to go fast or faster through a corner. Its simply an efficient way to select an appropriate lower gear to properly power out of a corner.
If you are compression braking than you are not really doing it properly and I agree with everyone that if you just want to slow down, use the pedal in the middle.
Besides its fun and a cool technique to try and master.
#74
I was just driving home from the store and realized that I do it all of the time. I just never paid attention before.
Pretty funny.
Pretty funny.
#75
I was told by a driving instructor that the reason for rev-matching was to get into the appropriate (lower) gear without "unsettling" the car. This, of course, is very important when setting up for a corner.
As I don't get to the track near as much as I like, I heal-toe downshift every gear at 90%+ of all red lights. It's great practice and it's fun to hear the Europipe burble.
