Tech HELP!!! My friends 996TT is sputtering...
#31
Originally Posted by MARKSKI
did he check all the coil packs???? actually I would repalce them as well just in case... but its too late already if u did the plugs...
I'll let you know what happens but so far he seems a lot happier and he says it is "fast as ***" LOL...wait till I get him into a hybrid turbo and ECU upgrade if not more! LOL
Thanks all for your help, keep up the ideas and I will report more next week!
Mike
#32
if its still stuttering a little the only sensible thing would be coils... I replace mine and dont any chances because labor alone will kill u if u have to take it a apart again....
2001 996TT 3.6L and stock ECU
#33
I will take the coils into consideration and make sure Dave will ask about it again.
Thanks Marski!
M
#35
we had stutters and replaced the coils and the problem went away.... sometimes visual inspection does not solve the issue... but in ur case its covered so no biggy....
#37
Check or change out the MAF.
A bad maf makes the car run too rich at cruise, so the ECU adjusts the fuel trims leaner to compensate. Then at full throttle over 3000 +/- RPM it's too lean, and you get a lean miss. My car ran like it had a clogged fuel filter or bad plugs but it was actually the MAF.
#38
The MAF was checked and it was clean and good to go, same iwth the coils...plugs have been changed and it seems that it is running fine...then Dave called me this morning...he has a CEL again.....shiet! I will be calling FabSpeed today to see what can be done...might have to go down the ECU upgrade road....Dave is NOT happy....I am bummed...
M
M
#39
M
M
#41
sorry don't know...he left a message and that was it...as soon as I find out i will post it up...
#42
sure thing...I appreciate all the help I have received! I hope we can resolve his issues...he hates CEL lights and it is part of the problem...hope to get to the bottom of it soon so he can enjoy his car again.
M
M
#44
Dumb newbie question here. What is a coil pack? How many are there? What do they do and what is there life span? Just trying to learn what to keep an eye out for. Also, what was the name of the shop in Annapolis?
#45
Coil packs are new versions of the distributor and coil. Each cylinder gets it's own coil for sparkin the plugs.
