Adjustable Toe Links - Camber - Tire Wear Questions
Old 07-02-2007 | 04:22 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
Here is my problem. The car is lowered with PSS9s.
I just got a flat in a canyon at night. It turns out it the right rear tire wore out on the inside within about 2,500 miles, down to the wire, and lost all air.
The left one looks just the same but is holding air.
Both tires have about 6/32" tread in the middle and outside. A new tire only has 9/32".
My camber is adjusted to the least negative possible. I think about -1 degree.
With adjustable tow links I'll be able to do better.
I have two options here. I can buy tires that are directional, not inside - outside specific - and reverse them after 1,200 miles. Or I can put in the adjustable drop links and hope they'll allow me to make the needed adjustment to my rear camber.
How many miles can I get from a set of rear tires with less negative camber and agressive driving and about 650HP?
Old 07-02-2007 | 04:41 PM
oak's Avatar
oak
sounds like you need upper dog-bone links to adjust camber, not the toe link. give mike at awe a call, he has some really nice set with rubber seals, just bought a set from him. great service. pleasant to work with. like the mailman he delivers, fast.
Old 07-02-2007 | 05:57 PM
SDEVILTT's Avatar
SDEVILTT is infamous around these parts
Are your wheels stock? also have you checked the inside liner for rubbing, I have seen this. I have got over 8K on my current set, I'm lowered on KW V3 coilovers. If can help call me 619-977-0832 Joe
Old 07-02-2007 | 06:00 PM
GT3 Chuck's Avatar
Administrator
the problem is probably not your camber as that is not very much...most likely a toe problem...how long since alignment?
Old 07-03-2007 | 02:26 AM
BlackBear's Avatar
The wheels are 19". It has been a while since the last alignment. Maybe two years.
I just took the car out with the new tires. It drives like $****. PSM kicking in all the time.
I checked the tire temps by hand. The inside is hotter than the rest of the tire. That would indicate that there might be a toe problem.
I had to raise the car last year about 1/4" and did not think I needed an alignment. How can the toe have changed when raising it?
Old 07-03-2007 | 04:50 AM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
Sounds like an alignment issue. I realign every time I change a tire period... It's cheaper than buying a new one or getting stuck in 2000 miles!
Good luck!
04-28-2022 01:38 AM
COBB Tuning
11-09-2015 09:02 PM
TrackOne
08-20-2015 01:56 PM
08-19-2015 07:35 PM
