silicon hoses upgrade - do it!
![Thumbs up](https://www.6speedonline.com/forums/images/icons/icon14.gif)
The other day, I was driving down the highway and started to pass a truck. All of a sudden I heard a loud pop and my car started loosing power. I pulled over and found that the passenger side IC boost hose and blown off. I ended up having the car towed to my shop and decided it was a good time to do the silicon hose upgrade.
Before the upgrade, the highest I was seeing was 1.0-1.1 bar sustained with spikes of 1.2. After having the new evoms silicon hoses installed, I'm now seeing 1.1-1.2 bar with spikes of 1.3. This is with no other adjustments. It's surprising that the stock hoses are so ****ty. Not only are the connections weak, but they leak boost like crazy. I've also noticed a slight improvement in throttle response after having the new hoses installed. Overall, I think this is one of my favorite mods. Not only are the new hoses a much needed upgrade, they look awesome too. The red IC hoses are actually noticeable from the rear of the car and really add a nice touch of color. Not to mention, the engine compartment looks great too. If you havn't done this mod yet... I HIGHLY recommend you get it done!
yeah its possible that my stock hoses were loose. But I've also read that they can leak a little boost anyway.
Originally Posted by KPG
A lot of times they arent even properly connected. You may have had hoses that only had one side of the connector clip in properly. I had it happen and made sure I heard a click twice every time I installed my hoses and never had a prob since and i was running 1.3 bar with LOTS of track time...
Originally Posted by cohare
Can you explain futher to a boost hose noob? I feel like I have a leak and want to make sure the hoses are connected correctly. Do you need to take the rear bumper off to make sure?
I installed the Evoms silicone hoses a while ago,I was very carefull to put them in till I heard 2 clicks but under full boost 1.2 bar they always managed to become loose a little bit.I finally got tired of taking my bumper of so a drilled a hole in the IC and the metal piece of the hoses and put in a screw.No problems for me anymore..
No everything is perfekt but it's difficult for me to explain in English but I'll try,hope you understand:
I drilled a small hole in the intercoolers and in the metal piece that sticks on the silicone hoose.I tapped wire into the metal piece ,than I put the metal piece in the IC and screwed a screw in it and put some locktide glue so the screw can not get loose anymore.Then I put the hose on the metal piece using clamps you can screw together.You have to make the large hole in the motor compartment where the silicone hoose go's through larger because otherwise you can not use aftermarket clamps.So the metal piece can not come out anymore from the IC but with the aftermarket clamps I can always remove the hose from the metal piece and change them if needed.Difficult for me to explain ,I should have taken some pictures..
Feelgood MD
03-24-2016 09:35 AM
faiz
09-02-2015 08:43 PM
ECS Tuning - VW
09-02-2015 09:03 AM
