Which are the best spark plugs for 996 Turbo X50
Old 08-14-2007, 11:52 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Originally Posted by MARKSKI
I thought Evoms switched form bosch to NGKs
Then EVOMS tried the Densos and, like Protomotive, they determined that the Densos work better.
Craig
Old 08-15-2007, 03:10 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Hey Craig, do you have a part number for those Densos? And is it suggested to run them one heat range colder?
Old 08-15-2007, 07:41 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Please post the exact Denso part number and how long one should keep them in the car (UMW Stage 1/2....)? Denso claims one can go much longer.....
Anyone thing this holds water? As an aside, I have asked about this and been told to stick to copper by some pretty smart people......so now I am confused.
TIA
JB
Old 08-15-2007, 07:45 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
For the horsepower I plan to run Im gonna stay old school with a copper plug. the NGK bkr7E has been tested numerous times with High horsepower Supras. When I put a set in my car the car immediately felt right. GL there are many options but 3 dollars a plug sounds pretty good no? proven
S
Old 03-16-2008, 05:59 AM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Part Number: PK20PR-P8
Stock Number: 3245
Denso: Double platinum
14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, Double Thick Platinum-tipped Ground Electrode and Platinum-tipped Center Electrode, Projected Tip, .032" (0.8mm) Gap
Triple platinum plugs offer long life and are typically called for on a Distributorless Ignition Systems (DIS). The platinum tip on the center electrode offers extended life, however the ground electrode has a double thick platinum tip for twice the life. This creates a long life plug with virtually no gap erosion, so that you will have optimum performance, longer. Copper core for better thermal conductivity. Machine rolled threads to reduce cross-threading and seizing . The plug insulator is constructed of purified alumina powder for extreme stress with 5 ribs to prevent flashover.
Does one install them as they come or should gaps be adjusted?
PelicanParts.com
996 Vendor Classifieds
08-20-2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
08-20-2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
08-18-2015 03:45 PM
PelicanParts.com
08-18-2015 03:43 PM
Quick Reply: Which are the best spark plugs for 996 Turbo X50
