FVD ECU upgrade Question
A friend of mine is considering upgrading his 2001 TT (K24's & Exhaust) to the FVD Stage 4 ECU.......can he just plug it in and go? Or does he have to have a dealer reprogram it before he can use it?
Chris
Chris
I have an FVD ecu that was a spare if you are interested. It has the latest program, and FVD was good enough to let me try several ecus before I settled on this program. It was in my GT2 that also had K-24s and Cargraphic exhaust. If he wants to keep his ecu stock, this may be an option. Evan at FVD can tell you if this is easily done.
Hi Chris,
does your friend have currently software installed on his car ?
We changed our ECU upgrades for most of the current Porsche Models. There is no more ECU swapping needed. You will receive a cable and software from us. With the software and the cable you will be able to read out your car. After you are done reading out your car the software will be transmitted to us via a secured internet connection. Then our programmers will look at your file and adjust it for your needs. After they are done coding it they will send the files to you. One is the original file and one is the tuned file. You will then be able to write the tuned file to your car. If you would like to write the original file back to your car (due to whatever reason) you can do that with the original file.
You need:
1.) Laptop or PC (Windows based)
2.) External Battery charger (just to guarantee constant power)
3.) Internet Connection
The reading out process (including upload) will take between 2-5minutes. The reason why I say 2 and 5 min is because it rerelies on your internet speed. It took me 5 minutes on a 996tt thru my blackberry and my laptop.
After you received the file you will be able to write the software on your car. This takes in general 5-10minutes.
If you should have anymore questions let me know.
Thanks, Flo
You need:
Thanks, Flo
Chris
Chris
Originally Posted by dgreen78
Chris, you will need to have it programmed to your VIN #. Any dealer can do this for about an hour charge. There are also a few guys on here that can do it for you.
He said you then have to send the ECU to the programmer to have everything put back on.
Now I'll be honest.....I tried to purchase an FVD ECU once and FVD wanted to charge me $1,200 to change the programming to my car
And they (it was a woman) acted like they were doing me a favor
Hi Shark, quick question what model was the software for ? Where was the ECU purchased ?
Thanks, Flo
Thanks, Flo
Originally Posted by Shark01
OK, this whole subject confuses me. I just called Stephen at IA, because my dealer refuses to touch non-approved mods and Stephen says yes, you can reset the ECU to your car.......BUT........you lose the performance programming on the ECU so all thats left is the stock programming.
It was the standard k-16 software package. The guy said he bought it from FVD. I didn't purchase it because the total price (the ecu plus the re-programming) was more than I would have paid to get it flashed and I admit I'm a bargain shopper.......err cheap-***
This isn't dissing the software, I really wanted to buy it (this was a year ago) but the customer service aspect was poor. If this policy has changed, then my death wasn't in vain
This isnt right. I sent my Used FVD ECU to Stephen to be programmed to my car and he said it was not a problem. Then when I got the ECU it was STOCK PROGRAMMING on it. He then stated the seller of the ECU must have ripped me off. Maybe Stephen can chime in?
Quoted from Stephen: "It is 95.hr and it will take 2 hours. It is an overnight thing. I will need your ECU currently and the FVD unit. As far as their programs I do not sell it nor know what specfically they have changed. I just have the ablity to look and write the codes including the embolizer codes."
"If I use the piwis then it would be changed to stock if I use the other program I have then I can just change that info not the whole program."
Correct, if we use the PIWIS the system will reset the whole ECU but will also send it back to stock. I also use custom software that alows me to change just the program and Embolizer codes. Two different programs. So If I do it like the dealer all bets are off. It is a stock program. Or I can just change that string and emboilzer codes. I have to have both ECUs to be able to read down the codes and transfer them.
Sorry for the confusion.
04-28-2022 12:38 AM
09-01-2015 03:16 PM
08-20-2015 12:17 PM
