semi-limp mode.. am I overboosting?
Old 07-15-2007, 09:30 PM
oak's Avatar
oak
oak is offline
this is the exact condition I was speaking about in another thread about upgraded wg's with out the correct program. ob condition and limp noodles.
Old 07-15-2007, 09:43 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I think there is a good chance it's adjustment, but if it turns out to be programming - the FVD stage 4 program was very happy with my upgraded wastegates.
Old 07-15-2007, 11:27 PM
kayman's Avatar
kayman is infamous around these parts
I'll have my mechanic adjust the wastegates with a pressure gauge. But I have a feeling it won't help much since the car is reverting back to limp mode even at 1.1 bar.
Is there anyway to check if the ecu has the GIAC software installed? I had my ecu flashed, but maybe the file didn't take. Is there something I can look for using a code scanner?
wross996tt: do you know if the GIAC software allows for ecu fuel adjustments? Very occasionally I get some momentary hestitation at full throttle followed with some popping noises from the exhaust.
Old 07-16-2007, 12:19 AM
John D's Avatar
If it's reverting to limp at 1.1 it's probably not the wastegate adjustment (unless your stock boost gauge is not reading accurately). Mine was running 1.2 and bumping 1.3 when I had the limp mode issue and adjusting it to read a steady 1.2 was all it took to correct it.
Old 07-16-2007, 12:26 AM
kayman's Avatar
I've seen spikes of 1.3.. does this mean that I may have been doing consistant 1.2 even though my gage didnt show it?
Old 07-16-2007, 12:30 AM
change ur plugs... also, who flashed ur ECU????
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 07-16-2007, 12:39 AM
kayman's Avatar
plugs were done about 2k miles ago (Bosch FR6 LDC)
Perfect Power did the ecu flash.
Old 07-16-2007, 05:49 AM
benguss's Avatar
benguss is infamous around these parts
I just had the same issue this weekend. I upgraded to k24 wastegate and cannot get the adjustment right. My question is: the correlation between bypass valves and wastegates. Mine ramps up so fast on initial throttle , it goes into overboost. I can't back off the wastgates anymore without opening them up (flaps) . If bypass valves are very stiff springs will this "ramp" up the turbos hence overboosting ?
Old 07-16-2007, 10:41 AM
mclaren55's Avatar
mclaren55 is infamous around these parts
When I go in limp mode I usually go downtown and pay $5 a pill for some viagra.
Old 07-16-2007, 01:00 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
you need viagra at 22? damn that sux
Old 07-16-2007, 01:09 PM
mclaren55's Avatar
Only when I'm jumping on the grenade.
Old 07-16-2007, 01:27 PM
drewTT's Avatar
LOL.......
Old 07-16-2007, 03:05 PM
Mikelly's Avatar
Being that I'm having some issues with codes as well, I'm all ears... been wondering is I need to ditch Upsolute and go with something else... I'm also wondering if I don't have a boost leak issue...
Mike
Old 07-16-2007, 03:22 PM
MexicoBlue's Avatar
MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !
Did you take Viagra and Ciallis at the same time? If so, then I would say definitely yes.
Old 07-16-2007, 05:18 PM
wross996TT's Avatar
Does not exist to my knowledge..you need a tuner that can handle Bosch code. GIAC is off the shelf (great for what it was intended). Talk to one of the tuners (I use Kevin).
Quick Reply: semi-limp mode.. am I overboosting?
