semi-limp mode.. am I overboosting?
Old 07-17-2007, 04:51 PM
kayman's Avatar
kayman is infamous around these parts
I'm going to have a local shop adjust the wastegates with a pressure gauge. Can this be done easily without removing the turbos and/or wastegates?
  #32
Old 07-17-2007, 06:02 PM
bring the car to me and Ill tell u what is wrong. sometimes even shops dont know where and what to do.... i had 3 turbo kits so I know...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #33
Old 07-17-2007, 06:08 PM
kayman's Avatar
Mark, you're the man! Just sent you a PM...
  #34
Old 07-17-2007, 06:55 PM
devious996TT's Avatar
devious996TT is infamous around these parts
sorry if this is an easy question, but I was wondering if the car goes into "Limp Mode" and if we do not reset the battery, would it reset itself sooner or later?.. or will it run in Limp Mode until you reset the battery?..
  #35
Old 07-19-2007, 10:37 AM
BMWDEMON's Avatar
BMWDEMON is a jewel in the roughBMWDEMON is a jewel in the roughBMWDEMON is a jewel in the rough
subscribed!
  #36
Old 07-20-2007, 10:48 AM
kayman's Avatar
I took it to a local shop today and the problem was definitely with the wastegates. I took the advice of some 6speed members and had the mechanic pressure test it and calibrate them to start opening around 12psi. I'm now getting steady 1.1-1.2 bar with no limp mode. Car is running strong and all is well. Just in time for the weekend!
Thank you 6speed!
  #37
Old 07-20-2007, 12:27 PM
when the car is in limp mode, what type of boost will you get?.. 0.5-0.7 max?.. will it hit 1.0bar at all when in limp mode?
  #38
Old 07-20-2007, 12:31 PM
oak's Avatar
oak
oak is offline
Thank you 6speed!
this is exactly what I mentioned in the last thread about this mod. at this point there isn't any gain if you have to crank down to 1.1 - 1.2, you can adjust the stocker up to 1.1 - 1.2. oh yeah. mad power.
Westy
11-16-2008 03:01 PM
il nino
03-23-2008 10:00 PM
Oliver B
03-20-2008 12:57 PM
2thfixr
11-07-2007 07:35 AM
BlackBear
05-06-2006 11:20 AM
Quick Reply: semi-limp mode.. am I overboosting?
