leaded fuel
Old 05-26-2008, 02:25 AM
BLKM3's Avatar
BLKM3 is infamous around these parts
DO NOT RUN LEADED FUEL!! I learn this the hard way having to replace my sparkplugs. If you have 02 Sensors and Cats, it will destroy them. Also you need to have the right program!
I ran leaded fuel and I have no cats, but I have 02's. I lost 200hp the car ran horrible. Stick with high octane unleaded!
Old 05-26-2008, 03:49 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Don't do it!
Old 05-26-2008, 07:56 AM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Originally Posted by contigo
I have no cats and my ECU is programed not to throw checks due to the cats, Can I do that mixture suggested? Will It be a good improvement?
Hi, Lead kills the o2s and plugs, I know for sure! I use sunoco 104 unleaded Same specific gravity as pump fuel. Vp is thinner then pump and will run a bit richer on as tune..... That could save your motor if you are using stock fuel system.
Hope this helps, Tim
Old 05-26-2008, 09:38 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I use VP MS 109. Runs better than the MS 103 and cost a little more (motor octane is slightly higher). PM me your number and I can tell you who sells it for the cheapest price in OC. I buy it in 5 gallon cans and use the VP pump I purchased off there web site. Now I beat up on my friends LP640, 997TT and 650HP Gallardo.
Old 05-26-2008, 05:07 PM
DLSJ5's Avatar
DLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond reputeDLSJ5 has a reputation beyond repute
Did you ever rerun Kevin's HPF M3 with your car running better?
Old 05-26-2008, 08:01 PM
wross996TT's Avatar
Just filled mine with VP 105 unleaded...man that sh*t smells really good and the car is lovin' it.
adnanm3
11-22-2023 02:43 AM
pwdrhound
09-13-2016 10:44 AM
Lucid Moment
09-12-2015 01:12 PM
916er
09-07-2015 09:50 AM
Quick Reply: leaded fuel
