lowering 996TT
Old 07-31-2007 | 08:02 PM
landjet's Avatar
lowering 996TT
Newbie question--when I lower my new car, do I need to buy drop links to install or is everything needed already there? Besides the new coilovers I mean.
Old 07-31-2007 | 08:15 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Larry, talk to Tom, they are absolute experts in that area. I believe that they are authorized JRZ distributors. Check out their website.
http://www.tpcracing.us/products/suspension/
Old 07-31-2007 | 08:39 PM
landjet's Avatar
Thanks Mario, I just looked at the site. I have H&R's on the 993 that TPC put on for the PO and I hate them. I think it's the springs. They transmit everything into the cabin instead of absorbing it. Just after you left the other night, Tom was moving cars back inside and he said the one regular 996 had JRZ's on it and asked if I wanted to take a ride. I thought they were racing shocks and would be hard but they ate the ruts instead of tranmitting them to the cabin. I'll have to seriously consider them.
What do you have on your car? Did you lower your car or was it like that when you got it? Will I need to buy any drop links in order to lower it?
Old 07-31-2007 | 08:55 PM
9Eleven's Avatar
That's the factory height on a Gt2, it's completely stock. I believe that Porsche uses H&R for their OEM suspension. I think you do have to replace the drop links because the body will be closer to the sway bar and the drop links can't be adjusted that far to compensate for the decrease in ride height, but I may be wrong. Tom will definitely steer you in the right direction when it comes to any suspension upgrades. I may be going by late Friday for a dyno run, if you have time come by and we'll talk suspension.
BTW, I took her out this evening; she's hitting 1.1 bar in 3rd and 4th right around 4700 rpm. I think one more waste gate adjustment and I'll see a steady 1.1 bar with a 1.2 spike. The car pulls like a freight train. I never imagined that an exhaust would enhance the flash by that much. If I knew that when I had her flashed, I would of bought that exhaust a year ago.
Old 07-31-2007 | 09:04 PM
landjet's Avatar
I'm glad you're happy with the exhaust and that it's doing it's job. What time Friday? I might be free and if so I might show up. I need you to take me for a ride in the chile pepper!
Old 07-31-2007 | 09:09 PM
700hp996tt's Avatar
700hp996tt is infamous around these parts
Landjet,
Are you the infamous landjet that used to own the black mr2?
Old 08-01-2007 | 07:30 AM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
Larry, The H&R springs only will do that, the shocks wear out prematurly, and when you have a shorter spring on a stock shock you just have that much less travel. Generally a coil over will have more travel room to compensate for the shorter spring. I just got the H&R coil over set up (spring + helper spring on a threaded shock body). It came with drop links for the front and I believe every Coil over set up will have them included.
I will let you have a ride when I put them on.
Old 08-01-2007 | 07:53 AM
Gert's Avatar
Gert is infamous around these parts
Originally Posted by landjet
.... I have H&R's on the 993 that TPC put on for the PO and I hate them. I think it's the springs.
Nope, it are the shocks that are dead.
Tired 993 Monroes all feel firm and harsh.
Old 08-01-2007 | 07:56 AM
SpeedYellow's Avatar
SpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura about
doing a full PSS9 kit will cure all of the problems. you get an adjustable ride height and MORE ocmpliant suspension than stock, depending on your settings.
Old 08-01-2007 | 07:52 PM
banditlex's Avatar
banditlex is infamous around these parts
I just had the porsche european X-73 suspension installed (with the swaybars) on my turbo cab. Lowers the car and handles great (although the engine mounts have to be changed to raise the engine a little). the american version is slightly different, but it works well also. The best part is since it is a porsche part, it should still be under warranty. Pss9s or any other aftermarket suspension will not be. Everything is preset from the factory as well (although the european version appears to have more adjustability that the american version- or at least that what I understand).
Old 08-01-2007 | 08:35 PM
wross996TT's Avatar
There are 2 versions of X73...news to me Suspension effecting warranty..I think not!
Old 08-01-2007 | 09:00 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
If your looking for the gt2 look stay far far far away from PSS9's... do a search many posts on this topic.
Old 08-02-2007 | 08:44 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Answer to your original question......do I need DLs as part of lower project......'yes'.
Adjustable DLs........otherwise you're bound to be preloading when you set new height and corner bal.
Many sources.....TRG and SCarGo are a couple.
Good luck.
Old 08-02-2007 | 08:07 PM
banditlex's Avatar
first, in response to the earlier post, the suspension won't affect the warranty, but if an aftermarket part such a component of a pss9, it will not be covered. if a porsche part fails, it will be replaced under warranty. As for the x-73, I was told the american version is slightly different, although that might only be true for cabs.
DLF
Cayenne 955/957
10
02-28-2022 11:49 PM
Zmydust
09-10-2015 12:31 PM
sparks
09-08-2015 03:03 PM
Zmydust
09-07-2015 01:43 PM
Quick Reply: lowering 996TT
