Track Junkie Questions....
Old 08-04-2007 | 12:33 AM
ccayer's Avatar
ccayer is infamous around these parts
Ok... so I have tracked the hell out of my car this... love it.
However I have a couple of questions for you guys that do this all the time. Running Michellin Pilot Sport Cups... what is a good HOT pressure for these tires... I'm finding if they go anywhere over 41/42lbs they loose all grip?
Our local track MURDERS left fronts... has anyone rotated the tires from side to side... I can't find anything to suggest it is a bad idea, they are not directional?
Thanks in advance,
Old 08-04-2007 | 10:26 AM
Dietz's Avatar
Dietz is infamous around these parts
Much much lower!
36 hot is the usual target, but some of my buddies run 28-32 hot.
34 front, 36 rear - try it...
Dietz
Old 08-04-2007 | 10:57 AM
Stocktriggers's Avatar
Stocktriggers is infamous around these parts
I start (cold) 28 front, 30 rear. When hot they end up around 36 front 38 rear which seems to be ideal responsiveness for me. If you adjust, do it by only 1 pound at a time (per run).
A better measurement in terms of consistent performance is inner edge, center, and outter edge tire temps when HOT - right off the track. You want a 1-3 degree variance from one side to the other. If the outter edge is 10+ hotter than the inner edge, add 1/2 to 1 degree of neg. camber and then retest. Once the tire temp is consistent across and pressure when hot is in the 36-38 range, you will get the most consistent grip in all situations around the track.
A pyrometer will measure this for you ... roughly $150 bux.
Craig
Old 08-04-2007 | 09:23 PM
al@cpt's Avatar
al@cpt is infamous around these parts
Please email me, ( al@gocpt.com )and i will send you a pdf on the pilot cups. Not sure how to post a pdf file here.
Old 08-05-2007 | 12:07 AM
ccayer's Avatar
My cold pressure all start at 32lbs or below. Depending on wheel. Friday's track day I started with the following, track temp 79 degrees.
LF - 29lb
RF - 30lb
LR - 30lb
RR - 31lb
Ending temps were...
LF - 43lbs
RF - 41lbs
LR - 42lbs
RR - 40lbs
How do you guys only raise the temp 4 to 8 degrees????
I have a pyrometer, consistant temps across the tire. Just chasing the right cold pressure... I realize it is dependant on temp outside etc...
Old 08-05-2007 | 06:17 AM
al@cpt's Avatar
Email sent.
Old 08-05-2007 | 06:53 AM
WOODTSTER's Avatar
I rotated my Hoosiers side to side because Brainerd Raceway also
murders the left side tires (especially left front). No Problemo, but
do not know about the Mich's. Your temps jumb too much! ??
MK
Old 08-06-2007 | 05:11 AM
LuisGT2's Avatar
LuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond reputeLuisGT2 has a reputation beyond repute
Thanks in advance,
Based on my experience (for my car - GT2) my cool presure is 26 f, 28r. That gives me the correct warm temp. during DE at BIR.
Yes, I rotated tires from side to side ones during a DE weekend.
Regards,
Old 08-06-2007 | 08:49 AM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
I ended up around 36f 38r and those turned out some GREAT feeling lap times...that being said, **** the PSCs and move to Hoosier R6s...they are WORLDS better with grip, run at 40psi hot and stick WELL after the PSCs lose it...
just a suggestion...
Old 08-06-2007 | 12:26 PM
heavychevy's Avatar
I not only rotated but flipped my tires (hoosiers) because of the neg camber I was running and the fact that I ran at Roebling Road and it ATE the outside of one of my tires so I had to to get any more life out of them. It took two heat cycles for the grip to come back, but it did.
Old 08-06-2007 | 02:52 PM
ef996TT's Avatar
ef996TT is infamous around these parts
At pacific raceways I start wit 26 front 28 rear cold works out well see you there
WearyMicrobe
12-10-2015 04:06 PM
Korntera
09-15-2015 08:20 PM
albert@velosdesignwerks
964
09-09-2015 11:48 AM
WheelB
991 Turbo Vendor Classifieds
09-03-2015 10:26 AM
Quick Reply: Track Junkie Questions....
