Should I fit K24 Turbos ?
#47
sorry for the late response. Sundays are crazy for me. Just walked in now. Anyhow you asked how much did i pay for my set up... without the exterior things it was something like this:
ecu 2975
turbos - 2500-2800 or so...
then the HYbrids conv another 1200....
Wgs are 400
greddy- 440
5 bar - 150 ( i have one brand new you can get)
intercoolers 1800
exhaust 1500 maxspeed
BOV agency power 300 or so...??
air filter came wit car....
clutch 1200 give or take
Hope this helps you out!!!!!!!!!!!!!
D
ecu 2975
Wgs are 400
greddy- 440
intercoolers 1800
D
#48
so i have an x50 right now.. stock.. im planning on going straight pipe.... and pondering a k18/24 with my current 24's... what price range should i expect to pay fro the conversion????? what is the best easyest tune/company to go with? be honest guy's.....
#49
I have had the the pleasure of driving a few K24/18gs as well as the one of a kind k24/20g.
the upgrade is I believe $1200 a pair. Then another $400 for installed and calibrated 12 psi WG springs. U can source out ur own 5 bar FPR.... get a greddy boost controller for $300 online.... Teh ecu I believe is $2975 onetime with option to upgrade and or retune for I believe $365. There is no need for program swithing cable nor a program what other tuners( not all) charge extra for because this is all in one... So meanwhile the initial ECU fee maybe 500 to 700 bucks more but in reality its the saem after all said and done. You dont buy cables nor "Race" programs for an extra fee... in this case you have a boost controller that controls your HP output. Teh ecu is written for this device and and you do NOT have the dreaded 1.3 bar limp mode like other tuners do. I have seen guys put on aftermarket WG springs to only kick the car into limp mode time after time. Those Ecus are not coded for the 1.3 bar limp bypass.
Yoy asked for the best tuner... I tell you there is no "best/easiest" as you called it...
Hope this helps....
Hope this helps....
2001 996TT 3.6L and stock ECU
#51
Markski, can you comment on the lag difference between stock k24's and k24/18's? I already have a big-turbo 951 that is almost undrivable on the street (track car), don't need two. Guess I'm leaning more towards k16/24's but don't want to upgrade twice.
#52
not bad.. so basically we are talking about $13-$14k + labor to get into tens.. really nice
ecu 2975
Wgs are 400
greddy- 440
intercoolers 1800
D
ecu 2975
Wgs are 400
greddy- 440
intercoolers 1800
D
#53
maybe even less.... I paid only 1300 for my turbos... I was relaly fortunate as someone was incredibly generous with me! the electronics yu can get really creative with and search online for... basically those prices is what ANYONE can get... If you spend some time as I did... yu can really find some awesome deals!!! but even at 12-13K.... ITS out of this world!!!
#54
Something else to consider is that the stock exhaust has 10+ PSI of back pressure. With aftermarket options you can get it down to less than 2 PSI. It is the difference between exhaust pressure in front of the turbo (inlet pressure) and after the turbo that causes that turbo to spin. If you decrease exhaust backpressure after the turbo you increase the difference between inlet pressure and the turbo spools up quicker.
IMHO if you are going to upgrade your exhaust don't waste your time on a K16 based turbo. The protomotive K24/18g's with proper exhaust are very responsive. They are nothing like old school 930's.
#55
cant stress enough how happy I am with my turbos! for the money spent I have a rocket! nevermind..money spent...its fast no matter how you slice it!!! nothing like some other members here...but... considering what I actualy hve modded...its not much to get these numbers!!! sooooo much fun to drive!!!!
#56
Hope this helps....
Hope this helps....
The hybid turbo is ok with the stock internals?? What hp with above set up?
thanks
tom
BlackMarketRacing
12-08-2015 01:49 PM
BlackMarketRacing
12-03-2015 10:46 AM
oddjob142
08-19-2015 12:27 PM
