Should I fit K24 Turbos ?
Old 08-11-2007, 05:39 AM
RCH's Avatar
RCH
RCH is offline
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
is this really worthwhile + approx what are the costs involved please from those with experience ?
Old 08-11-2007, 07:06 AM
RCNJ's Avatar
RCNJ is infamous around these parts
My recommendation is k24/18g conversion with Protomotive and it will definitely be worth your while.
Raudel
Old 08-11-2007, 07:20 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
what is the difference between k24/18 and k24/16 in terms of performance and cost? and more importantly, which has less spool up lag?
Old 08-11-2007, 07:32 AM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
MAJOR $$$$
Nothing wrong with a set of k-24s and a flash, assuming you have a decent exhaust to help shorten the spoolup time.
You will be sitting at 550 hp at the crank for minimal cost
k-24s $2,500 if you shop around
Programming $1,600 from FVD, about $3,000 for GIAC
Old 08-11-2007, 07:46 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Please look at Kevin's Stage IIIUMW release data or call him. He has a new K16 unit that pushes air like a k24 but is fast to spool up.....a new turbo on the market. I am of the opinion that Kevin, as the turbo maker himself and not just a seller of turbos, has the product of choice. I would talk to him about turbos and review your wants and needs..... I gain nothing from this post. I am just a satisfied customer. I am not posting the link to his announced product because I don't want to be banned....but you probably should find this data before spending any money on x, y, z....get your full data in hand.
Most on the board may not know there is another turbo now out there, I don't even know what to call it. It is a k16 but with a custom casing, etc.
If Kevin is here, please pipe in. I don't want to say the wrong thing, etc.
JB
Old 08-11-2007, 07:47 AM
Dub-U!'s Avatar
Dub-U! is infamous around these parts
K24/18G = K24 + ~ $1k
Nothing wrong with just going plain K24s and ECU though - make sure you get wastegates.
Old 08-11-2007, 08:02 AM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
JB
It is not an entry level turbo though.... 996TT section of Rennlist.com
Old 08-11-2007, 10:19 AM
FL TT's Avatar
FL TT is infamous around these parts
The difference of CFM produced by K24 vs k16 at same boost pressures is significant. I would highly recommend pairing stiffer wastegate springs and ECU tune.
Old 08-11-2007, 10:51 AM
It comes down to a few things...
K24s with a flash( good)
K24s with upgraded springs and a flash( better)
K24s with 18g compressors(apprx. $1000 extra) with flash( even better)
K24s with 18g compressor with upgraded Wgs plus flash(best)
One advantage to going k24/18gs is that you can always upgrade to a
700 hp package without upgrading turbos once the k24/18gs are installed.
I think we all are speed junkies and I personally have changed turbos 3 times.. so saving yourself 4 to 6 K on a set of turbos would be nice.
I personally had k24s with and without upgraded springs...
There are other tuners that offer different turbo packages.
just my opinion...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 08-11-2007, 11:18 AM
wross996TT's Avatar
What he ^ said!!!
Old 08-11-2007, 12:11 PM
RCNJ's Avatar
just my opinion...
markski
I just got my car back yesterday from Protosport. I did the k24/18g 700 package and thats exactly what I did. About 9 months ago I did the 600 package and now upgraded to the 700 and you don't feel it in the wallet as bad. But you definitely feel it on your ***.
Old 08-11-2007, 12:50 PM
Dragon911TT's Avatar
Dragon911TT is infamous around these parts
markski
Markski - when you say "upgraded springs" are you referring to the wastegate springs? Can you point us in the right direction on these? Where to get them and how much should we expect to pay?
Old 08-11-2007, 01:02 PM
Evoms, Protomotive, UMW, etc.. they all have it.
be aware though that some have 1 bar springs and they tend to be a little too strong... thus harder to control especially when it gets cold.
I suggest a 12 psi spring so ur minimum boost will be 12 psi...
The real problem in buying just the springs is that it is somewhat difficult to set them up so they work correctly.. especially when guys are running ECUs that have the 1.3 bar safety shut down mode... ( most do). What happens is that when the Temps. drop a little then the car boost more and if ur setting is set too close to 1.3 bars then the car goes intyo limp mode. I know from experience. Its tricky but can be done correctly.
SOme, like protomotive, use a EBC and control the boost via the cockpit - nice
9.66
click to view
Old 08-11-2007, 04:55 PM
Dub-U!'s Avatar
An EBC w/ lo & hi settings Though 100+ octane fuel is > $7/gallon around here and our cars are thirsty suckers.
I'll write more about my experience w/ upgrades soon but you can never have enough HP for giggles. In reality, on the street and track stock is more than enough true performance...
Old 08-11-2007, 07:05 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Depends on what you want to do and how much hp you want in the end. My advice... Find some people with setups your looking for and ask for a ride. Try a flashed, exhausted k24 system with wastegate springs, a simliar 16/24 hybrid setup, and 24/18g set up and see how you like each, then decide. Good luck!
Quick Reply: Should I fit K24 Turbos ?
