waste gate question
waste gate question
Just bought the Evo wastegates and put them on two K24's sitting on my workbench.
Question for the experts:
Are the wastegates supposed to be vacuum adjusted after the turbos are installed on the car or can they be adjusted on the work bench prior to turbo installation?
Thanks Gents
Sameer
Thanks Gents
Sameer
Originally Posted by 9Eleven
The EVO WG are awesome, I used to hold 1.2 bar until 4,400 rpms now look (the boost is much sooner 0.9 bar 3,200 rpms):
http://www.youtube.com/watch?v=XvQYrBrdn4A
Originally Posted by Pierre996TT
It is look good for me, I used a tire pump.
What ECU flash program are you using? GIAC?
I've read that the GIAC flash and waste gates are compatible, but if you try to use the EVO waste gates with a different program (i.e. REVO, Upsolute, UMW), you may encounter overboost problems.
this is the vacuum tester I am planning on using
http://www.automotion.com/productpag...acuum%20Tester
$44 from automotion.com
But back to the question, new wastegates are on the turbo's- but do I do the vacuum adjustment before or after I put the turbo's back on the car?
waste gate
its not vaccum presure you want its boost presure i found out the hard way becuase the wastgates work when presure is pushed in if you use a vaccum tester it wont do any thing and it might ruin the inside of your waste gate
Originally Posted by steve harris
have kevins k16s adj wast gates 1/2 turn two much?? this shortens the travel assume it opens sooner ??? or am i going to get more boost??
I hope it helps
Regards
