Sway Bar Help
Old 08-21-2007, 07:29 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
Sway Bar Help
have 01 with pss9"s lowered whats the best sway bar???
Old 08-21-2007, 07:35 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
H&R front and rear, or GMG's set.
Old 08-21-2007, 11:25 PM
fly2low's Avatar
fly2low is infamous around these parts
GT3 is another option
Old 08-22-2007, 02:28 AM
CarNerd's Avatar
Definitely. Not as thick as the H&R's or GMG's but more cost effective. Can't really go wrong, i've heard good things about all of them. I personally run the H&R's, but only b/c GMG was out of stock at the time.
Old 08-22-2007, 04:45 AM
landjet's Avatar
Don't forget the TRG sways.
Old 08-22-2007, 08:58 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Turbo Performance Center offers some VERY beefy sway bars.
Craig
Old 08-22-2007, 09:06 AM
tom kerr's Avatar
If you only have the PSS9's wont matter much. and really wont matter what you choose as all above are better then stock.
I went with the GT3 sway, it is hollow and light and from porsche. the others are probably every bit as good.
bottom line is probably not what sway you add but did you add one.
Old 08-22-2007, 10:09 PM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Will GT3 front sway bar fit AWD 996TT? Where can I get a set of GT3 sway bar? Please advice thanks!
Old 08-23-2007, 01:11 AM
fly2low's Avatar
Got them on mine, front and back. They are a Porsche part - so local dealer, Sun Coast, Pelican maybe, Carnewal, Sunset, etc., etc
Old 08-23-2007, 05:33 PM
tom have pss9's guess the gt3 will be the right move thanks steve
Old 08-23-2007, 05:54 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
GT3rear is fine, I don't think GT3 front will work without different drop links. The rear is all you need. I have that on the second to stiffest setting and it is on rails. Pss9 set at 3front 2 rear. It is a little stiff but handles SWEET. The corner balance and aggressive alignment don't hurt either. Good luck.
Old 08-23-2007, 08:09 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
So the stock tt rear end links work with the GT3 rear bar? I heard from one dealer that I'd need different length end links to go with the GT3 bar. I'm also running PSS9s set to 3/2.
Jeff
Old 08-23-2007, 09:36 PM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Jeff
Jeff, I just ordered GT3 sways front and rear and Sunset told me the drop links in the rear are 30mm too short. I ordered a set of very beefy drop links from The Racers Group they look great although they have not been installed yet. Kevin
Old 08-23-2007, 09:47 PM
MidnighTT's Avatar
I expect to hang with a couple of TRG guys at Sear Poin, errrr Infineon tomorrow for the Indy car race. Maybe I can score a discount! It turns one of my coworkers used to crew for Kevin Buckler, and he asked if I wanted to tag along tomorrow.
Jeff
Old 08-23-2007, 09:49 PM
KPG's Avatar
KPG
KPG is offline
Jeff
At 600$ a set, better start shmoozing early . They are great quality though and cannot be compared to stock.
