Got the Motons, Roll Bar, GT3 sways..
Update...
I got the stuff on it now.. I figured I needed to replace my X73 with something a little stiffer (and I loved my X73 setup).
The car now has GT3RS motor mounts, GT3 sways (front & back), DAS rollbar and Motons. I didn't get to take it for a big run as it was on the way to the bodyshop to start it's exterior update.
Cantel motorsports did the suspension and bar. They removed the rear seats, rear seatbelt hardware, rear wiper, rear wiper motor, and rear speaker cabinet. Really clean work, I love the X pattern in the back of the rollbar. I have some seats (Sparco DTM's) on oder, but need to lose a few pounds because I'm certain my fat *** won't fit in em!
I received my hood and wing from MA Shaw. They are pretty good. The wing is nicely done, not sure about the edging on the leading edge (it's a solid tone to hide the seam I guess, but it's not as sharp as the real CF GT2 wing) and the hood is perfect except right at the bottom edge. I'm going to have the clear tinted black to match the car and hide a lot of the CF detail so the little errors likely won't show.
I should have the car back next week, so I will take some pics!
Seth.
Seth.
It was probably overkill for my uses, but with the UMW ZC setup I wanted to make sure it would handle.
Seth.
X73 to motons is probably a big jump. The adjustability freaks me out (even the Adjustable sway bars freak me out). I'm not sure what any of the adjustments mean, but the shop that installed them told me they put everything in the middle and to come back to them if I find anything too soft, too hard, too bouncy, etc. and they would adjust it. I haven't had time to run it up and down my personal racetrack (I live on one of those super twisty freshly paved roads you seen on cartoons).
Seth.
Seth.
Yes there is a huge difference between PSS9's to JIC to (really big jump) motons.
the problem here is that most of us dont have the skill or crew to properly dial something like that in!!
I would compare your lap times with each change. this is the only way to see if it was "worth the money" to you, not someone else.
I went JIC first with the thought of easy to sell and upgrade if I want. I took 8 seconds off my sebring lap time with the new set up. If I went to motons I may have taken off 9. so for 4k less I'll wait a year. but motons are in my future as well (hopefully they will be attached to a Cup car)
Slowmo congrats!! let us know what happens to lap times.
Is there a big improvement from Pss9's to the JIC's?
I am getting Kevin's ZC set up soon and will then be doing some suspension. Almost all street for now, but some DE events booked. (Who knows I may get hooked)
yes just at least in the adjustability and height adjustments, no more hitting the bump stops.
I meant that as a question. I dont see where a coilover application cant give you 8 seconds from another coilover, at least on the same car (everything else being equal). I would even say that is a stretch from stock to coils. 8 Seconds is a LONG time, and I have always been under the impression that on any car, Tires will give you the biggest impact, weight second, and coils somewhere around third.
I do concede the Sebring is very long, but I still think something else helped you get that 8 seconds, did you do anything else in the meantime? Pads, new tires, anything?
motons
On my lowly C2, Motons improved my time at Road America by 11 seconds. The car was stock except for Sport Cup rubber before then and I timed my change after installing the Club Sports. What a magnificent setup. So I would believe that he got 8 seconds at Sebring. It transforms the car completely to a predictable and exceptional handling beast.
great choice and enjoy
SlowMotion,
How does the Das rollbar fit? There is no drilling correct? And does it come in black, I dont like the shiny bars, and dont want the trouble of getting one painted. Any idea on the weight?
