Michelin PS2 (not Cups) track pressures?
Last time I was on Hoosiers, this time my lowly street tires:
Front Pressures Cold==
Rear Pressures Cold==
F hot =
R hot=
Track day tomorrow with the Corvette club.
F hot =
R hot=
best way is to get a contact pyrometer and just check the temps across the tread. Add/bleed air as needed to get even temps across. Be prepared for some serious understeer BTW. Hoosiers > Ps2 is an unhappy transition
Woodster,
I think the 34f and 36r cold is about right. Check temps after hot and bleed fronts to 38 hot and rears to 40 hot and you should be fine. Remember, smooth is fast and easier on the tires. You have PLENTY of power to make up any differenc on the straights. Don't over drive the tires or they will get greasy in the high heat. Enjoy!
I've measured my (non cup) PS2s at the track using a pyro-meter as suggested here; I found 34psi hot front and 38psi hot rear gave the most even temps across the tyre surface and the best grip (as good as you can get on streets anyway....).
The other thing to keep in mind is your highest grip levels will probably be on the first 3-4 laps - after that the street tyres heat up too much and become very very skaty.
Cheers,
Beej
Cheers,
Beej
04-28-2022 12:38 AM
L.A.P.
10-19-2015 10:01 PM
L.A.P.
08-23-2015 11:48 PM
