HELP!! Car won't boost over .9
Old 09-13-2007 | 06:24 AM
Maximus's Avatar
Maximus is infamous around these parts
My car is at Perfectpower, Sol is trying to figure out why it will only boost .9 bar. They already found and fixed several boost leaks but when test driven still only .9 bar.
Frustrating, not to mention EXPENSIVE!!!!!
Old 09-13-2007 | 07:00 AM
sdorn's Avatar
sdorn is infamous around these parts
Should it boost over .9 bar? What kind of car do you have? What mods?
Old 09-13-2007 | 07:15 AM
Maximus's Avatar
Yes, with the Evo Stage4 GT640 kit it will boost 1.2-1.3
Old 09-13-2007 | 07:19 AM
sdorn's Avatar
Something must be wrong then, you should get that fixed.
Old 09-13-2007 | 08:28 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
I concur!!!
Old 09-13-2007 | 09:37 AM
S-351's Avatar
S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !
Most likely...You blew off the pipe from the Y to the throttle body.
S-351's Avatar
Just me guess though. It had happen to me in the past..And the WOODSTER.
Old 09-13-2007 | 10:59 AM
Thats why having an ecu that does not have TB shutdown is nice.
Just wait till it gets colder.
Didint u put on some upgraded WGs or something?
disconnect the battery for 2 minutes, pull back the WG springs.... and pressure test the car.
Sol knows what to do.
Markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 09-13-2007 | 11:06 AM
S-351's Avatar
Markski
Agreed..pressure test.
Old 09-13-2007 | 11:41 AM
MariusL's Avatar
MariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the rough
On the subject.. what boost should I see on a stock GT2?
Old 09-13-2007 | 05:49 PM
Maximus's Avatar
Markski
Didn't you have this kit at one time on your car??, Sol threw on an analog gauge and guess what it was boosting fine so we thought the sending unit for the digital gauge was bad, Sol got on the phone and was now told that the program won't let the car read anything over .9 Bar
We are having trouble believing this especially when I got on the phone to the shop I bought the kit from told them the problem and was told there was probably a boost leak never was I told that the program limited the boost to .9
So here I sit $3,000.00 dollars later with that as the outcome
Old 09-13-2007 | 06:20 PM
unvmy996's Avatar
fawk , sorry to hear .... did u try what mark said ?
Old 09-13-2007 | 06:39 PM
oak's Avatar
oak
that doesn't sound right. what type of programming are you running?
Old 09-13-2007 | 07:56 PM
Maximus's Avatar
It's the Evo Stage4 GT640 kit. Sol fixed all the leaks, there were several but none of them were that big. The system has been pressure tested and is fine, I am going to replace the sending unit just to see for myself but am sure I have seen over 1.2 bar in the past.
Old 09-13-2007 | 08:33 PM
jamie furman's Avatar
jamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond repute
My stock GT2 made .8.
Quick Reply: HELP!! Car won't boost over .9
