BOOST Hose ISSUES!!!!
The rubber seal has nothing to do with this! My point is that the diameter of the connection is different to that of the Y pipe. i.e. If you were to make a perfect fitting connection for the intercoolers ends, I guarantee this would not be able to fit into the Y pipe end.
Andyk79, in the world of Mitsubishis, we used T-Clamps which are heavy duty clamp that will surely do the job. Just do a search. They should be easy to get at a hardware store. The problem with the stock clamps are that if u torque too much they will break. If the pipes are different sizes u cannot tighten the stock clamps enough as they will break. Checkout another post on this site that mentions the problems associated with the 2001
Turbonetics T-Bolt Clamps is what 4G64T is referring to (I'm also an old-school Mitsu guy). Available at Jegs, Summit, and Turbonetics.
These will hold any amount of boost you throw at them, however you run the real risk of either breaking or deforming anything you clamp due to the high torque ability.
These are useful only if you are using the EVOMS intercoolers where you remove the machined ends of your hoses and clamp directly to the IC pipe. You can use them on the turbo outlet, but IMHO it's overkill for stock turbos.
http://i145.photobucket.com/albums/r...actoryhose.jpg
If you look at this picture, do you mean the red hose is pulling off the metal end or that the metal end is pulling out of the turbo. The second right?
no room between the firewall and all connections to even access if you could. even if you could the hardware is too bulky, the fenderwell is in the way.
5/8" width band on the t-band hose is still too thick. it may clamp ok for awhile but the clamping/squeezing pressures due to the oversized width of the band over the machined barbs on the turbo would eventually slice into the hose. make sense? no?
nlakind
11-06-2015 11:15 AM
