Range 2 Over-revs
Dude, whether you want to believe it or not, you're wrong. I'm tired of members on this forum spouting out misinfomation as gospel, then claiming that you have to prove them wrong. Plain and simple, type 2's are over revs during a mis-shift or down shifting into the wrong gear, those can be fatal. Type 1's are during acceleration and hitting the rev limiter which are lot less damaging. Now, why don't you prove us wrong.
Yes, you can also create a type 2 by downshifting into the wrong gear. But as far as I know and have been told by trusted mechanics, tuners, race car drivers and race crew chiefs, a type 2 is not associated with an upshift that bounces of off the rev limiter, period. Listen more talk less, you might learn something.
Jeff
**I** am tired of people taking what Porsche says is 'true' as gospel, and accepting their explanations as fact- given the fact that we haven't a clue at the algorithm nor software that captures this data. Porsche may truly believe it to be true, but I for one would love to look at their software validations and cross examine their software engineers on this stuff.
I wonder if this 'fact' eminates from one 'lie' (ie Porsche) and now we have hundreds of people all being considered 'truth speakers' ("old by trusted mechanics, tuners, race car drivers and race crew chiefs").
But I'm just a cynic...
A
I've followed the type two discussion for a while- and midnight certainly has proven that in his case, hitting the rev limiter resulted in the DME capturing type2 faults. (Unless you want to declare him a liar.)
A
A
Does anyone have any factory info or experience that describes "Type 1, Type 2" and "Range 1, Range 2"? Early in this thread, both sets of terms were used. Are these synonyms? Or, does the chip actually capture over-rev events by the level of RPM's AND by the type of event that caused it?
I just got back from clearing my codes, and checked my overrevs:
Number of ignitions range 1 8247 / 962h
Number of ignitions range 2 707 / 957h
Operating hours counter 964
It had 21 Type 2's when I bought the car last year, and I have never missed a shift (missed a shift up once at the strip and went into 5th doesn't count). Type 2 can be caused by hard shifting, or bouncing off the limiter when tires lose traction. The only difference between a Type 1 and 2 is the RPM that it happens at. This has been thoroughly discussed before 9Eleven, do a search - you are incorrect.
The rev limiter is not a hard mechanical stop - it is an electronic deterrant if anything (cuts spark). Believe me, hit it hard enough (i.e. accelerating hard enough), and you will go through it.
The only time I see a variance is when you downshift into the wrong gear or miss the gear entirely, engage the clutch and throttle back on in neutral. In that case the rev limiter cannot react in time to intervene; consequently you can sustain severe damage. I will also ask, if bouncing off the rev limiter upshifting is not a type 1 over rev, then what is?
Just a foot note, I went by Atspeed motorsports on Thursday. They had a 997 Gt3rs on the lift. It was getting a new clutch. The reason? Missed downshift. They estimate that the engine rpm's hit over 10k when the clutch blew. He was lucky, the clutch saved his engine.
I'm not trying to convince you, I'm just stating fact. Even if spark + fuel is cut (there is no "mechanical clutch") via the electronic limiter, you can still be accelerating hard at the time and go well past it. The clutch never is disengaged, so the engine RPM will still be rising at the limiter due to the wheels turning (all the boost in there helps). Physics is a *****.
