New Product Release : Standard Issue 996TT Diverter Valves
Standard Issue Diverter Valves where designed with the Porsche 996TT in mind, using a side vacuum pipe to allow for easy routing inside an already crammed engine bay. These billet diverter valves dump charge-air back into the air intake system and keeps external noise to a minimum. Featuring a piston design which is superior to the factory rubber diaphragm, this DV allows for quicker throttle response, higher clamping load, and more reliable control of boost pressure. The units are machined from billet aluminum and come only in a stealth black anodized finish. As with all Standard Issue products we pride ourselves in function over form, with products guaranteed to perform.
Pre-Order Online Special Price : $219.00/Pair
**Ships in 7-10 days**
Purchase them online at Titan Motorsports : SI 996TT Diverter Valves
**Will Also work in all VAG 1.8T engines, all VAG 2.7 Bi-Turbo engines.
We've tested this valve on many appilcations including the 996tt and 2.7t Audi S4 (high boost application).
After comparing to many other DV's, you can expect to see quicker boost response and no boost leakage issues.
The valves are also serviceable and rebuildable, meaning there will never need a need to replace another DV again.
A+ to Titan on this one .
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
ModBargains
08-20-2015 12:28 PM
Nissan GTR
08-19-2015 02:11 PM
ECS Tuning - VW
08-19-2015 08:58 AM
