Every Pagid Brake Pad You Need - Blue, Yellow, Black, Grey, Orange
Vivid Racing now has one of the largest online catalogs of Pagid racing brake pads for popular track vehicles. We carry the Pagid Black, Blue, Orange, and Yellow pads for different models. Pagid pads are available to fit both aftermarket racing calipers and OEM brake systems.
Order ONLINE or you can PM or Call Me Directly.
The Pagid Black RS 14 Brake Pads Medium high friction racing compound with high initial bite, excellent release characteristic, very good modulation (controllability) and due to the high ceramic content low heat conductivity. RS14 has a low wear rate and is fade resistant up to a temperature of 650 deg. C .
The Pagid RS15 Grey Brake Pad High friction racing compound with high content of ceramic materials, fade resistance up to 700 deg. C (1,300 deg. F). It combines a 20% higher friction value than the RS14 with a slightly increased pad wear. Although the RS15 has a good controllability and release characteristic it needs finesse to avoid over braking the car, especially with lightweight cars or cars with boosted brakes.
Pagid's RS19 Yellow Brake Pad is the best compound for endurance racing on the basis of the RS14. A slight reduction of the friction value improves the modulation (controllability). Nevertheless, the friction value is enough for cars without power-assisted brake system and ensures comfortable low effort on the brake pedal. Constant temperatures up to 600 Deg. C (1,100 deg. F) are possible. The combination of friction value, fading stability and low wear rates on pads and discs (rotors) realised with this material is unmatched up to now.
Pagid's RS 4-2 Blue Brake Pads are a very common pad that street and track drivers use alike. The medium friction racing compound with immediate low temperature response. Fading resistance up to 500 deg. C ( 930 deg. F). The RS 4-2 beds quickly and has a very good modulation (controllability). It is a classic Rally compound and one of the most commonly used pad in small single-seaters. Can be used as a rear pad in combination with a higher friction front pad.
The most popular brake pad for street cars is the Pagid RS 4-2-1 Black. The high performance compound with low fading characteristics and high cold friction. The RS 4-2-1 is a most comfortable medium friction compound and very easy on the discs (rotors). Very popular for brake up grades or tuning. It is OE on various Super Sports Cars among others Aston Martin, Bugatti, Ferrari, Lamborgini, Lotus or McLaren. Suitable for street and light track use such as track days or driving education.
Next, Pagid's RS 4-4 Orange Brake Pads are a medium friction racing compound with a higher average friction value than the RS 4-2. It is disc friendly with a predictable, non-aggressive friction behaviour (stable torque). Fading resistance up to 560 deg. C (1,050 deg. F). It is a very good rear compound for touring car applications in combination with RS 14 front pads. Application: Club racing (very popular in Porsche club racing).
View more of our Brake Pad Applications at our online store here - http://www.vividracing.com/catalog/b...4238_5307.html
2lflat4
11-18-2019 05:05 PM
PelicanParts.com
08-20-2015 02:45 PM
PelicanParts.com
08-18-2015 03:51 PM
