Spring Special on Innovate LM-1 Wideband
-$279.00 FREE OVERNIGHT SHIPPING
If you're running additional boost, or trying to make the most of your setup, monitoring Air Fuel ratios is critical to maintaining a proper tune. The Innovate LM-1 handheld wide band allows you to monitor air fuel ratios easily, and can be moved from car to car quite easily as it relies on a standard 12V outlet for power.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program as seen in the picture above.
The Basic Kit includes: the Meter, a Bosch wide-band oxygen sensor and cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual.
Purchase Online :. LM-1: Digital Air/Fuel Ratio Meter
Write in the comments field you purchased from 6Speed and we will remove the shipping and include one of our super badass Titan Camo Maglights.
(shipping will be manually removed after checkout before card is charged)
PelicanParts.com
09-11-2015 12:11 PM
PelicanParts.com
996 Vendor Classifieds
09-11-2015 12:08 PM
PelicanParts.com
996 Turbo Vendor Classifieds
09-11-2015 12:06 PM
PelicanParts.com
997 Vendor Classifieds
09-11-2015 12:06 PM
PelicanParts.com
997 Turbo Vendor Classifieds
09-11-2015 12:05 PM
