K16, X50, GT2 and More SOFTRONIC ECU Flashes on Special - Save 20%
SPECIAL PRICING good till September 30, 2009!
K16 ECU Flash - Retail $1549. Your Price $1395
K24/X50 ECU Flash - Retail $1549. Your Price $1395
GT2 ECU Flash - Retail $1549. Your Price $1395
K16/16G ECU Flash - Retail $1995. Your Price $1695
K24/18G ECU Flash - Retail $1995. Your Price $1695
K24/20G ECU Flash - Retail $1995. Your Price $1695
Custom Garrett Turbo ECU Flash - Retail $1995. Your Price $1795
All ECU Flashes receive the following: Raise Rev Limiter 500rpm, increase O2 variables to not throw CEL on high flow cats or catless exhausts, option to raise boost cut off, retain original map for easy loading back to stock.
Future Tweaks
Dan:
A few questions:
What hp and tq increases I can expect on a stock X50 with this initial flash? I am in Houston running 93 Octane.
Are there different file options depending upon where I want to see improvements, ie quicker spool up and lower end acceleration vs top end, etc.?
I also see in your ad, there is no need for multiple files whether using pump or race gas...how does this work??
What is your policy on a future flash? (Example: If I flash it now with stock K24's I see the discounted price...lets say 6 months from now I upgrade to K24/18g's and need an updated file to go along with it, what would I need to pay for the re-flash at that time?
Thanks,
Ken
A few questions:
Thanks,
Ken
Great questions. I have MANY customers in Houston running the Softronic flash. The stock X50 you should see a good gain in both HP and TQ. The limited factor on the X50 car is the stock exhaust and the diverter valves. Right now you run about .8 or .9bar. With the flash, you should see about 1.1bar when you have an aftermarket exhaust and new DV's. If you were to do a before and after like this, you would see a gain of around 40HP and 50ft/lbs of torque. See more info here - http://www.vividracing.com/catalog/s...0-p-45747.html
I also offer a exhaust, DV, flash package with our Agency Power product. Contact me for specials.
Because the car is tuned off the stock knock and O2 sensors, each individual table is mapped to adjust and change to different octane. Others do a GLOBAL change to the ECU parameters that will not work the same which require a different map. If you decide to add the K24/18G later, what is nice about Softronic is again you flash with your OBDII cable, they have a PROVEN and successful map, and it only costs you $400 for the update.
Dan, is there any picture of this client-cable unit? i'm guessing that it serves the same function as the GIAC hand-held unit?
Damn, I'm newbie, so it does not allow me to send PM. Here is what I was gonna ask vividracing:
Hi there,
I just run into your promo on 996 TT ECU yesterday. Few quick questions:
- Do I get to save both old and new profile? I'd like to know that I can switch back and forth whenever I want...
- Is Softronic offering several profiles of different degree of aggressiveness? I've seen some other companies do it, and supposedly you can choose between more power and better drivability.
- Cable included in $1200? Could you ship to Washington? I'll be at a conference there soon, and I don't want to deal with brokerage etc (I'm from Canada)
- Upgrade is $400 if I change setup (new exhaust etc), right?
- And finally, I usually use 94 gas available in Canada, if I run update while using 94, and system adjusts to it, what will happen when I use 91? Is this safe?
Thanks a lot, I realize this is a lot of questions, my mobile is area code 416 and rest of the number is 856.9856, feel free to call if it's easier. I'm very likely to order this product, just awaiting answers.
Thanks, Zhelko
Hi there,
Thanks, Zhelko
Welcome to the forums! Feel free and call me to discuss.
With Softronic you keep your Original File as well as the new tuned file. You can flash back and forth if need be. Softronic gives you 1 tuned map and it is the best one the first time. It will adjust to different octanes, exhaust, etc. No need for map switching. It is safe, reliable, and gains quite good power. If you order TODAY ONLY, the cable is included in the price. The $400 change is only if you go to bigger turbos, fuel injectors, cams. Basic bolt ons do not require a reflash. 94 octane is no problem as we have a map which is 93 octane.
Thanks for the call and order!
Check out our Agency Power exhaust - http://www.vividracing.com/catalog/a...5-p-33955.html
Here is the Diverter Valves we were discussing - http://www.vividracing.com/catalog/a...5-p-53979.html
09-01-2015 04:16 PM
08-20-2015 01:17 PM
