USP Motorsports 996TT / GT2 Intercooler upgrades - $1490 shipped!!
![](http://uspmotorsports.com/images/usp_logo_1.jpg)
USP Motorsports 996TT / GT2 Intercooler upgrades - 800+ hp
These are direct bolt-on intercoolers used on my personal 720+whp 996 trapping 146 in the 1/4 mile!
Details and ordering information below
![](http://uspmotorsports.com/images/usp_996_ic111.jpg)
996TT Bolt-on Application
The USP Motorsports intercooler upgrades provide better cooling efficiency for charged air, compared to OEM turbo or GT2, resulting in more power to the ground. An aluminum bar and plate design is utilized opposed to the factory plastic end tank, tube and fin design. The cores use a high density of fins inside the tubes for quick and efficient heat dissipation while utilizing a slightly less dense outer fin setup to provide excellent flow. This technology provides maximum cooling with minimal pressure drop.
Our intercoolers install just like factory and require minor trimming on the shrouds due to the cores being 40% larger then stock. They are high quality hand made and pressure tested, so each set guarantees attention to detail. OEM C-clip hose connections are retained for installation for an OEM style fit.
Proven
Here at USP Motorsports, we stand behind what we sell. These intercoolers are used on our very own shop 996 Turbo making over 700whp. Videos can be found here - http://www.youtube.com/watch?v=Z6J9FOF3JSg, http://www.youtube.com/watch?v=GnhJZ984Rks
Click images to enlarge
![](http://uspmotorsports.com/images/usp_996_ic_comparetostock_sm.jpg)
![](http://uspmotorsports.com/images/usp_996_ic_incar1_sm.jpg)
Dimensions
Core Size: 16" x 9" x 3.5"
Overall Size with End-tanks: 23" x 9 x 3.5"
Inlet/Outlet Diameter: 2.5"
Charge Side Area: 30.6 cubic inch / side
Core Volume: 504 cubic inch mass / side
Core Volume vs. Stock: 40% larger
Performance
Efficiency: 89%
Flow rate: 750 CFM per side
Leak Tested: @ 35 PSI
Pressure Drop: less than 1%
Support HP: 800+
Click here to order
** use coupon code "uspicfs" for free shipping **
awdbiturbo1
02-18-2016 10:24 AM
Chris Green@USP
997 Turbo Vendor Classifieds
01-28-2016 02:22 PM
ECS Tuning - VW
08-21-2015 09:11 AM
Chris Green@USP
996 Turbo Vendor Classifieds
08-20-2015 11:30 AM
996, 996tt, 997, dimensions, gt2, intercooler, intercoolers, motorsports, oem, size, tested, tt, turbo, upgrade, usp
