996 Turbo Vendor Classifieds
Improve Braking and Step Up to 350mm Rotors - Starting at $150
Old 09-24-2010 | 11:01 AM
vividracing's Avatar
The Porsche 996 Turbo and C4S model was designed and built with high performance braking in mind. However, this amazing platform has now become a popular vehicle for the track use. With track racing comes the needs for improved braking over what the stock 4piston 330mm brakes can handle. Brake engineering at the simplest is about how you can have clamping force over a large surface area and dissipate the heat to keep the brakes from fading. What Agency Power has engineered is a Plus 1 Bracket Kit which allows you to take the factory 4piston 330mm brakes and upgrade to the 350mm OEM rotors that are found on the Porsche 997 Turbo. This bracket kit is essentially a spacer that goes between your caliper and the wheel carrier to allow your caliper to fit over the larger rotors. The larger rotors will give you increased surface area to provide you better braking and longer pad life. Our brackets are CNC machined 6061 aluminum to keep the weight down. Since this is an important safety component, we have had the brackets hard anodized. The kit includes longer bolts needed to install as well as new washers. Each bracket is laser engraved with the AP logo and if it is a front or rear unit. Each Kit is sold as a pair of fronts or pair of rears. These kits fit all 2001-2005 Porsche 996 Turbo or C4S with standard non ceramic brakes.
Agency Power Plus 1 Brake Brackets - 330mm to 350mm.
Here is a Plus 1 Bracket and 350mm Rotor Package
Here is my Stage 2 Brake Kit with Pads and Lines as well.
Old 09-24-2010 | 11:04 AM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
Thanks for still making 996 parts!
Any before and after results?
Old 09-24-2010 | 11:07 AM
There are a handful of guys running custom or other plus 1 kits. The after results you would see would be less brake fade, better pad wear, and improved pedal feel. For the power your car will have, not a bad thing to help slow you down!
Old 09-24-2010 | 11:57 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Do you have the lighter 2 piece rotors at the lager 350mm size?
Old 09-24-2010 | 12:07 PM
Yes sir... and I owe you a favor so let me know if interested.
Front Brembo - http://www.vividracing.com/catalog/b...e-p-58443.html
Rear Brembo - http://www.vividracing.com/catalog/b...t-p-59615.html
Old 09-24-2010 | 12:20 PM
drhenrock's Avatar
Now the tricky ?, is there any wt. savings from stock 330mm to 2 peice 350mm + brackets. Trying not to add Any unsprung wt. Thanks.
Old 09-24-2010 | 12:43 PM
The rear Brembo 2pc rotor weighs 17lbs which saves 5lbs per corner over the stock 997TT drilled Rotor. The front rotor I cant find the actual weight but my notes say it is 3lbs saving per corner. I have googled and cannot find what the stock 996C2 rotors weigh.
Rear weighing - http://www.vividracing.com/forums/pr...-vr-997tt.html
Old 11-19-2010 | 01:06 PM
Brackets are instock for immediate shipping!
Old 11-20-2010 | 07:27 AM
Ducgsxr's Avatar
Ducgsxr is infamous around these parts
Will these fit underneath the stock 18" 996TT wheels?
Old 11-22-2010 | 09:46 AM
Yes absolutely.
04-28-2022 01:38 AM
awchristler
Bentley
08-24-2015 04:53 PM
ECS Tuning - VW
08-20-2015 04:07 PM
TrackOne
08-20-2015 01:56 PM
