VRtuned 996 Turbo ECU Flash
Looking for easy and affordable power for your 996 turbo? Here it is!! The 996 turbo is arguably one of the best tuning platforms out there, with huge power gains seen from a simple flash tune. This is without a doubt, the single best upgrade in terms of price/performance out there.
Crank Horsepower Ratings:
Stock Power - 415HP and 413ft/lbs
Tuned Power - 495HP and 503ft/lbs
With the VR Tuned ECU Flash, basic bolt-on performance parts will not require a retune of your ECU. Adding parts such as an exhaust, headers, air intake, throttlebody and plenum, will all adjust with the tune. Raising the secondary O2 limits for cat delete or high flow cats as well as raising the rev limiter is available upon request. If you add higher octane fuel, the ECU will adjust accordingly. Anytime you add higher octane, the fuel will burn slower providing your vehicle with improved performance. We never recommend using leaded gas such as C16 as this will destroy your O2 sensors and catalytic converters. Further custom tuning is available with provided dyno sheets or datalogging.
How to flash?!
With the VRtuned, you will be sent a VRtuned cable kit...
That will allow you to get a read out of your current ECU, email us the stock file and then we will email you the tuned file to be uploaded the same you you got the read out.
Any questions at all, feel free to reach out! I am always offering 6speed member discounts
Thanks Rich
If there is a tune already on the car this will overwrite it. How it works is we will send out a cable kit that you would use to get a read out of the file currently on the car(usually stock), once you have that you will email it to us and we will send you back a tuned version of that file for you to upload. So you will still have the original file and the tuned file that you can flash back and forth between.
-Austin
