Brembo 2-Piece Floating Replacement Rotors for 996 C4S
Brembo 2-piece direct-fit replacement rotors for 996 C4S and Turbo cars that came factory with the 330mm steel front brakes (non-PCCB). These are designed to work perfectly with the factory calipers and pads, and are even finished to match the rear rotors aesthetically.
But because of their 2-piece full-floating design with billet aluminum hats, they are lighter and much more effective at heat dissipation than the stock rotors. These rotors are very similar to those in the Gran Turismo big brake systems, and use the same McLaren hardware.
These are a great option for those of you who would like to keep the stock calipers and improve braking ability at a more affordable price!
Pricing info is on our site here: Brembo 2-Piece Replacement Rotors
It may seem like alot, but when you consider that the cheapest GT Big Brake Kit for the front is ~$3500, it starts to make more sense. You are are basically getting a full-floating GT-spec rotor in the factory size, and perfectly matched aesthetically to your rear rotors.
These are really geared you guys that want a significant rotor upgrade but would prefer not to move to a larger caliper/wheel. The improved performance will be especially noticable at the track, where the advantages of heat dissipation are much more evident.
04-28-2022 12:38 AM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
PelicanParts.com
996 Vendor Classifieds
08-20-2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
08-20-2015 02:40 PM
