Help Please, My wheels are rubbing.
how wide are the wheels and what is the offset?
Looks like wrong offset. If it's rubbing at rear I would change the wheels, however if it's rubbing front only at full lock it can cured with fender roller.
Ideal offset for 19" wheels on narrow body 996: 19X8.5" et 56 mm and 19X11" rear with et 67 mm IMO.
P.S: Sorry about my English punctuation I know it means lot to you.
I have gone through a lot of wheels and lowering. Usually when you lower it, it will start to rub. Never heard of it vice versa.
There is a plastic ridge just forward of the tire tread, behind the bumper cover. The tire will rub that area especially if 996 GT3 spec's are used.
It does look like the rear wheels are a bit agressive. How about a rear 3/4 shot of the car so we can see that area.
as you start to lower the rear, the geometry of the suspension will start gain negative camber. as the suspension articulates up into the wheel well you will gaine even more neg camber.
if the plastic ridge you speak of is the same as for the turbo, if the suspension is stock of set close to stock depending on the offset and width it will rub due to the ridge being at the height of coutour of the tire. once you lower the suspension the ridge will be below the height of contour and should eleviate the rubbing.
And then we get an alignment to correct the negative camber caused by lowering and we are back to point A.
Depends on if he goes for an aggressive alignment or not.....An aggressive street or track alignment has more negative camber than the stock setup....With my stock 18s and a lowered car and aggressive alignment my rears looked so puny because they were in far too miuch...19x11's fixed that problem.....
most prefer more neg camber when lowering to enhance handling. dependant on prefered handling and practical reasons if you wan to get back to stock camber in the rears you will need to install upper dog bones to get back to stock camber settings. then you open up another can of worms in your wheel offset, depending on the amount of neg camber and wheel offsets/tires.
Oak,
If we use your avitar as a reference the ridge that I am speaking of is forward of the front tire at the 3 o'clock position. It is about 6 inches from bottom to top. The 996 GT2 and GT3 have a different fender liner without the ridge, the cars are lower, they have more negative camber and the stock tires on the stock wheels rub at full lock. Because the body work is the same on the GT2 and Turbo or GT3 and narrow body 996 many wheel manufacturers use the specifications for the GT2 and GT3 to make wheels for the 996 Turbo and 996 narrow body. That is when there can be some rubbing that needs to be addressed.
Thanks everyone for your help. Thank god I didn't listen to you guys and take a flamethrower to my car. Finally HRE stepped in to help. The problem was the oversized tires the last owner had on the wheels. The fronts were 245/35/19 they said they are suppose to have 235-35-19. Have a pair on its way and will install on Friday. Yeahhhhhhhhhhhhh
