Suggest a 4 channel amplifier
Old 02-19-2008, 04:48 PM
flash80's Avatar
flash80 is infamous around these parts
Originally Posted by bruceinmiami
my head unit is a Panasonic mp3/cd player. comparable to this one:
http://www.crutchfield.com/App/Produ...00&c=3&tp=5684
although ugly and non intuitive to use, it works fine-it's got the features i need. apparently no head units produce much more than 50w x 4, so i won't upgrade for power either.
is this amp a good hoice for my non-guru needs? i always thought Alpine was top-of-line stuff. guess not!
http://www.crutchfield.com/App/Produ...MRPF250&tp=115
or this sony, which is really small dimensionally
http://www.crutchfield.com/App/Produ...158XM4S&tp=115
I'd take the Alpine between those two (I'm not a big fan of Sony Xplod stuff). Amongst the cheaper Crutchfield amps listed, I'd go with this infinity:
http://www.crutchfield.com/App/Produ...08R475A&tp=115
  #32
Old 02-19-2008, 09:02 PM
bruceinmiami's Avatar
bruceinmiami is infamous around these parts
flash, you recommendation is for more power than the basic 50W x 4 i was originally shopping for? i don't really need a lot of power, but i don't want to "under-do it" either.
thanks for your help. you can tell i'm a noob on this stuff!
  #33
Old 02-19-2008, 10:00 PM
viper501's Avatar
viper501 is infamous around these parts
You will get better response / clarity out of an amp that isn't being overworked. Get an amp that will be more than adequate for your speakers and you'll enjoy better quality sound, regardless of the volume. However, understand that a big amp can destroy small speakers at very high output levels.
  #34
Old 02-19-2008, 11:48 PM
flash80's Avatar
I wouldn't be too concerned with the stated power output. If you actually tested these guys, the output would probably be close. Anything above 50 watts should be plenty. I wouldn't worry about getting too much power to your speakers. Boston Acoustic comps can take plenty of power. The more power, the more "headroom" you'll have--that means that you can basically crank it until your ears bleed and it won't be distorted.
I just like Infinity amps more than Sony or Alpine (although there's nothing wrong with Alpine).
  #35
Old 03-13-2008, 05:22 PM
CS Jeff's Avatar
CS Jeff is infamous around these parts
In my last car my sub and amp were Elemental Design. They're a great bang for the buck internet audio company. I highly recommend their stuff if you need a nice amp. The nine.4 is their 4-ch amp.
http://www.edesignaudio.com/index.php?cPath=1_22
  #36
Old 03-13-2008, 07:16 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Alpine makes a quality product.. Stay away from Sony, I find the newer stuff to be over-rated on claimed watts
  #37
Old 03-13-2008, 07:31 PM
redline C4s's Avatar
redline C4s is infamous around these parts
i had jl and loved it but i have also heard the alpine and they sound great and are very small.
just make sure you don't overload the speakers with to much power otherwise you'll fry them. the jl's are very nice because they send the same power to speakers in a certain ohm range so when it says 75 watts it doesn't vary depending on the ohm level. a speaker at 4 ohms and one at 6 will see the same power
  #38
Old 03-14-2008, 02:08 PM
ClayMan's Avatar
ClayMan has a spectacular aura aboutClayMan has a spectacular aura about
I'm partial to classic Phoenix Gold amps myself. They're ZXti and Ti series have been great to me. And look the part too.
  #39
Old 02-13-2010, 05:49 PM
Rthomson's Avatar
Rthomson is infamous around these partsRthomson is infamous around these parts
Originally Posted by waipahu996
Consider the Alpine PDX 4.150 amplifier (4 x 150 watts) It's smaller than the Porsche CD changer. It costs quite a bit more, but it fits in the trunk without losing luggage room. Also since it is a digital amp, there is no overheating issue.
Do you know if the Alpine amp will work with all 6 speakers (2 dash, 2 rear & 2 subs in the doors)?
BT
  #40
Old 02-13-2010, 06:03 PM
Doug996InKC's Avatar
Doug996InKC is infamous around these partsDoug996InKC is infamous around these parts
Audison amps are VERY versatile, in that every cross-over, gain, etc. is built into the amplifier. I purchased a 6-channel amplifier (and 1 channel for subs). Here's an install I did last summer:
http://dougturner.com/porsche/sound_system_2009/
  #41
Old 02-13-2010, 07:31 PM
fourempties's Avatar
fourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond repute
-1 SONY. Crap. Junk. Fill in the blank.
  #42
Old 02-14-2010, 04:15 AM
Steven B's Avatar
Steven B is infamous around these parts
Pay a little more and get quality - your amp is hugely important to the ultimate sound (with good speakers) and IMO you cannot have too much power. You can always remove it if you sell your car. Look at it this way: Let's say you have a flood in the basement. A sump pump with twice the capacity will move the water out more easily with less heating up and will be smoother and last longer. You will not regret spending a few $ more. My $0.02.
  #43
Old 02-14-2010, 07:03 PM
jr1966's Avatar
jr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nice
I have this amp in my........Jeep Wrangler. It is a full-range Class D amp, very compact (that I was able to mount it in between the seat tracks under the driver's seat) and the sound is decent for a full-range Class D. Been there for 2 years now with, a lot of times, having the interior exposed to moisture, and still running strong. IMO, it is a good amp, good enough for the Jeep but, to the OP, your P-car deserves something better. I wouldn't want a Honda-level Xplod amp in my P-car. There are a lot of options out there.......Audison, Memphis, JL, Zapco, etc. and they have some models that are surprisingly inexpensive.
  #44
Old 02-16-2010, 02:37 PM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
Focal 4.75 or Solid 4
need4speedmotors
996 Turbo Vendor Classifieds
01-12-2016 05:41 PM
7thsign
12-12-2015 07:43 PM
need4speedmotors
997 Turbo Vendor Classifieds
09-28-2015 04:47 PM
BauerR
09-28-2015 11:36 AM
Quick Reply: Suggest a 4 channel amplifier
