Flickering Brake Lights??
Just had my audio upgrade done (post on that later). One problem I've noticed is that my brake lights are either not coming on, or they slightly flicker when the pedal is depressed. Sometimes the break lights will come on every few pumps. I figure this is a nicked wire or something, but not sure. They're looking at it today/tomorrow.
Fuse is good. Brake sensor under dash appears fine (plunger works, wire connector is secure). It's not a bulb issue since it affects all 3 rear lights. Breaks work fine when driving.
2004 C2 Cab
Any ideas?
2004 C2 Cab
Any ideas?
I had a light issue like that. It turned out to be a loose headlight connection.
When I removed the headlight I found that the plug at the frame side was not secured by its' clip. After securing it and putting light back in, all was well.
GSR Autosport
08-26-2015 05:20 PM
