I moved the rear spoiler switch...
Old 04-26-2008, 12:49 PM
HxCforlife's Avatar
Awaiting Email Confirmation
HxCforlife has a spectacular aura aboutHxCforlife has a spectacular aura about
After learning what that switch on the fuse box does a few months ago i found myself reaching down a lot more to make the wing go up and down but it started to get annoying reaching down while im driving. Whenever there is a hot milf behind me or on the side of me i like to play with the wing to get them excited haha.Ladies dig the movement...But i figured just buying a new switch and relocating to a more reach-able spot would do me great so i got a switch for a buck and put it next to the cd holder,no more reaching down
Old 04-26-2008, 01:27 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
You also could have gotten a Porsche switch that fits in your dash and is designed just for that....and it wouldnt look like you rigged it....
Its the middle switch in the pic....
Old 04-26-2008, 01:30 PM
HxCforlife's Avatar
Yep your right haha oh well how much is that switch ?
Old 04-26-2008, 01:32 PM
newport996's Avatar
about $20.
Old 04-26-2008, 01:39 PM
HxCforlife's Avatar
Where did you get it?? And does it just plug into the harness that the fues box switch is plugged into now?
Old 04-26-2008, 01:41 PM
sportmpower's Avatar
sportmpower is infamous around these parts
It gets the ladies hot? Great, shouldn't have switched to a fixed wing.
Old 04-26-2008, 01:45 PM
newport996's Avatar
Dealer....Not sure how it plugs in, but is no harder than what you did. Your car may be prewired for it since its a Porsche option.
Old 04-26-2008, 01:46 PM
Steve Germany's Avatar
Steve Germany is infamous around these parts
What is the part numer for the wing switch? Over here in Germany the parts guy does not speak english. Part numbers work wonders for me!
Old 04-26-2008, 02:36 PM
himself's Avatar
himself is a jewel in the roughhimself is a jewel in the roughhimself is a jewel in the rough
Complete DIY on spoiler switch:
http://gallery.rennlist.com/gallery/albur35
-td
Old 04-26-2008, 03:42 PM
djhill's Avatar
djhill is infamous around these parts
Wing switch
Does the switch also lower the wing at high speeds? Or only rase it at lower speeds like it does know at the stock location.
Old 04-26-2008, 04:31 PM
himself's Avatar
All this does is physically move the switch.
The operation is the same. Push "up" button to raise, hold down "retract" to lower it.
Or, it does so based on speed.
-td
Old 04-26-2008, 05:57 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
If you use this switch with the DIY it overides the automatic function when you use it. i.e. if you raise the spoiler with the switch it will stay up until you lower it with the switch. Once lowered it goes back to the auto mode.
Old 04-26-2008, 10:08 PM
orangec2's Avatar
orangec2 is infamous around these parts
Its Turbo Rear Spoiler Switch - 996 613 155 00 A02 "Glossy" finish
Turbo Rear Spoiler Switch - 996 613 155 10 A05 "Matte" finish
I installed the Glossy in my center console and I parralleled it off the bottom switch. So, I can use either one of them to raise and lower the spoiler. looks clean and lights up at night, like the other center switches.
Old 04-27-2008, 05:04 AM
-td
Thanks - yes - I should of searched but I'm approaching my 100th post
Old 04-27-2008, 05:09 AM
Does any one know which model uses the switch or is an exclusive option?
The part number is not in the renntech link
Quick Reply: I moved the rear spoiler switch...
