Sound System in the 996?
Old 07-17-2008 | 08:17 PM
erubin's Avatar
erubin is infamous around these parts
Throwing in my 2 cents. I have a Reus system and have to say it sounds great. I have been in other Porsches with custom installed systems and have yet to hear one that sounds better or more balanced. I also have not seen one with a more professional and stealth install. The sound and quality of the install has been confirmed by friends who have ridden in my car and the local custom installer who replaced my Eclipse head unit with a Pioneer Avic nav unit.
  #47
Old 07-17-2008 | 10:53 PM
nine9six's Avatar
nine9six is infamous around these partsnine9six is infamous around these parts
Doesn't Reus put tweeters in the mirrors? Tweeters in mirrors and sound quality doesn't belong in the same sentance.
Now if we are doing a movie setup which requires a center channel. Thats something else.
  #48
Old 07-17-2008 | 10:57 PM
wicked 7's Avatar
wicked 7 is infamous around these parts
I will be posting a full detailed review of the entire REUS process as soon as mine is completed. I have already completed the initial install but I still have some pending issues.
  #49
Old 07-17-2008 | 11:02 PM
TriGem2k's Avatar
TriGem2k is infamous around these parts
Wicked,
If have alternator noise make sure they don't install a Ground Loop Isolator... This is never the proper fix in a high quality system.
  #50
Old 07-17-2008 | 11:08 PM
wicked 7's Avatar
Originally Posted by TriGem2k
Wicked,
That's not the pending issue but thanks for the tip - I appreciate it. Unfortunately, I am out of town until late next week. Upon my return I'll be in touch with Rick. Once completed I'll post an accurate review of the process and equipment as well as the final result.
  #51
Old 07-17-2008 | 11:53 PM
silver_6r's Avatar
silver_6r is infamous around these parts
my car has alternator whine... what do i do...
  #52
Old 07-18-2008 | 01:12 AM
fotostars's Avatar
fotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud of
Just upgraded to the AVIC F900BT from Pioneer. A ton of issues with the unit.
Waiting for a firmware fix. Stay away from it for now.
  #53
Old 07-18-2008 | 01:17 AM
TriGem2k's Avatar
Foto,
I installed the F90BT a few weeks ago and only have minor problems with it. Pioneer issued a statement saying there will be a firmware upgrade by the end of this month.
Are you part of Avic411.com?? If not check it out, the got some great info on there.
  #54
Old 07-18-2008 | 01:18 AM
TriGem2k's Avatar
What type of system do you have?
  #55
Old 07-18-2008 | 11:07 AM
silver_6r's Avatar
Pioneer AVIC-D3 navigation with 10" Polk Audio Sub, Macrom 5.25" + tweeter setup, 2 Digital Design Amp( 1 powering sub, 1 powering front channels)
it all looks clean... and the noise isnt too bad.... but i can hear it
Rod
  #56
Old 07-18-2008 | 12:01 PM
erubin's Avatar
I had this same issue. I cured it by turning down the gain on the amps. Unfortunatly I do not remember which amp was responsible. a little trial and error and you should be able to figuire it out.
  #57
Old 07-18-2008 | 12:07 PM
erubin's Avatar
Is your bias agianst mirror mounted tweeters based on your experience with them? Personally I like the brightness and sound quality they supply. I am not looking for a boom box with 4 wheels but a balanced system with good bass response, good sound staging, and accurate music reproduction, that I can enjoy while driving with the top down.
But to your point it also sounds great while watching DVD's in my car.
  #58
Old 07-18-2008 | 12:37 PM
TriGem2k's Avatar
Rod
Try grounding the RCA cables coming out of your Pioneer Avic D3. Pioneers are known to have this issue.
You can also try and relocating your crossovers (if you have any). Sometimes these get placed next to too many car control modules and get interference.
  #59
Old 07-18-2008 | 01:01 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
Rod
my REUS system had whine/engine noise coming from a specific speaker, i remember driver side tweeter in the mirror. turns out it was just a shorted out wire that lost it's insulation during install.
whine is always fixable, just need to find the problem
hope that helps
  #60
Old 07-18-2008 | 03:37 PM
silver_6r's Avatar
well...the mid-tweeter crossovers are in the trunk... right in front of the amps... and how the heck do you ground RCA's?
Quick Reply: Sound System in the 996?
