seat belt not retracting well
Old 12-07-2008 | 04:03 PM
EB847's Avatar
EB847 is a jewel in the roughEB847 is a jewel in the roughEB847 is a jewel in the rough
my driver side seat belt is slow to retract and needs some feeding. anyone have a fix besides replacement? dealer suggested soapy water. i wonder if it's a lubricant issue or spring.
Old 12-07-2008 | 05:32 PM
Redridge's Avatar
even though the belts does not look twisted... it can be twisted in the pillar section that can affect the spring return...
Old 12-08-2008 | 12:47 PM
porsche4391's Avatar
porsche4391 is infamous around these parts
mine is he same way...let me know if you find out anything
Old 12-09-2008 | 07:44 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
+1. hopefully something other than replacement.
Old 12-09-2008 | 12:13 PM
racesx's Avatar
racesx is infamous around these parts
+2 It's starting to get annoying as it started about a month ago for me.
Old 05-07-2013 | 04:46 PM
Diesel117's Avatar
Diesel117 is infamous around these parts
I know this is an old thread but did anyone find a solution? Replacement the only option?
Old 05-08-2013 | 07:10 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
No, mine's doing the same thing, you have to help it a little. I'm going to just live with it.
Old 05-08-2013 | 08:56 AM
Diesel117's Avatar
I am going to pull the seat belt to its max and try a little silicone spray on just the edges. If it discolors or doesn't work then I will replace it.
Old 05-13-2013 | 01:25 PM
Diesel117's Avatar
Just to update, the silicone spray worked.
I took a new tooth brush and water with a splash of soap and scrubbed the entire seat belt. It was really dirty. The black plastic eye loop at the top seemed to have worn its top coating onto the aging belt. I used Scott blue towels to get the belt as dry as possible.
Then I used the silicone spray on about 1/3 rd of the seat belt (the bottom end that retracts in). The seat belt soaked it up like crazy. I retracted the belt multiple times. The only drawback is the odor the spray gives. I knew this already as I use the spray all the time on the rear window of my Ford F250.
After two days I sprayed (soaked) the seat belt in febreeze (max strength), wiped it down with Scott blue towels, and the smell is almost gone. I will do another round of febreeze this week and I think I will have saved half a grand. Total time less than one hour.
Old 05-13-2013 | 02:38 PM
Dennis C's Avatar
Usually I can correct this by simply pulling the belt all the way out and then letting it retract. I like the cleaning ideal though - I may try that.
Old 05-13-2013 | 02:42 PM
32krazy!'s Avatar
whats the name of the spray you used?
Old 05-13-2013 | 05:40 PM
Diesel117's Avatar
Trust me, I tried that first.
Old 05-13-2013 | 05:48 PM
Diesel117's Avatar
Liquid Wrench brand silicone spray. I know there are others but that was the only one I could find when looking to fix my truck a few months ago (so I had it on hand already).
It is a strong odor (like WD40 but stronger) especially in the Texas heat so keep that in mind. The frebreeze is neutralizing it though.
Old 05-18-2013 | 08:59 PM
Diesel117's Avatar
Ok, just to follow up...
The second round of frebreeze did not neutralize the silicone spray odor enough for me so I was thinking of ordering a steam cleaner like the Wagner 915 or something. (about $100 and I can use it for many other things). Then I remembered I had a cheap hand held steamer I haven't used in years for clothes.
I steamed the seat belt for about 20 minutes and I think that did the trick.
Rockinc1
09-30-2015 07:44 PM
HIGHcard
09-24-2015 09:09 PM
oo7
09-10-2015 09:08 AM
Saint Ari
09-04-2015 04:30 PM
