Help with Cab Top Needed
Not sure if anyone else has experienced this, but I thought I would ask.
PROBLEM: Hard top will not raise or lower unless I use the key in the door to raise or lower the top.
ISSUE: As most know, to engage the hard-top to go up or down you must 'click' the handbrake up a notch or two. The problem I am experiencing is that the dash light that normally light's-up will no longer light up (fyi, the hand brake still works fine). I used to be able to "wiggle" the hand brake during the up & down movement so the light would come on and then I could use the normal in-car methid via the dash switch to operate the top. This has now ceased working and the e-brake dash light never illuminates.
SOLUTION?: Does anyone know what I should look for when I pull the console out? Loose Wires, Connections, Maybe a wood bracket missing?!? (you will get it if you read the other post...)
Any thoughts or ideas would be appreciated...
Thanks,
Tim
Thanks,
Tim
Very common. I had to replace mine as well. The switch is a wear item that will go out over time and will not allow you raise/lower the top without a functioning swithc that will illuminate "PARK" on the dash. Just need to replace it. There was a thread on this recently over on renntech.org that you may want to search for.
Thanks guys...
Any idea what the part looks like, or costs? I have never pulled the console to see what the "guts" look like underneath...
Fadi
08-21-2015 03:43 AM
