LED Tail lights
Old 03-10-2010, 07:29 PM
Sharky996's Avatar
Sharky996 is infamous around these parts
Originally Posted by CayenneS2083
I wouldn't stick it on the light. I've been running resistors for my front leds for a while and they get extremely hot. I suggest you run a longer wire and attach it to some metal just in case.
I did think about that before I stuck it on the light. My reasoning was that the resistors shouldn't get any hotter than actual bulbs themselves, which are housed in the light cluster anyway, in close proximity to the opposite side of the same area that I placed the resistors. I am under the impression that the housings, while they could still melt under high heat, should be able to take the heat generated from bulbs, etc.
However, I could be wrong about this. Do you guys know if the resistors would put out more heat than the bulbs would?
  #197
Old 03-10-2010, 11:03 PM
orangec2's Avatar
orangec2 is infamous around these parts
I was worried about the heat too. That is why I mounted my on the metal section back by the pigtail. That way I had an air gap for the heat to dissipate.
  #198
Old 03-11-2010, 09:28 AM
Tupe's Avatar
Tupe is infamous around these parts
Thumbs up
I have to say, those look really sharp!
  #199
Old 03-11-2010, 11:52 AM
MishaDesigns's Avatar
A+ Lights
  #200
Old 03-25-2010, 10:23 PM
Vipercliff's Avatar
Vipercliff is infamous around these parts
I received the lights today. After connecting them, the only lights that work are the blinkers, however they blink fast. Aside from the blinkers I have no other lights? Please advice.
  #201
Old 03-26-2010, 06:26 AM
Sharky996's Avatar
That's strange. Your reverse and fogs use the same bulbs as before, there are no LEDs for those, so they should work as before 0regardless of having change the light assembly to the new one.
The LEDs connected should now have replaced only the brake/main light dual filament bulb, and the signal bulb.
Given that you have the signals working, but blinking fast, means you will need the resistors.
As for the brake/main light LEDs, you should check the connection again to see if you have inserted the dual filament style bulb base from the new light (it has the base but no bulb) to the car's bulb connector.
  #202
Old 03-26-2010, 01:40 PM
Vipercliff's Avatar
I have three blown fuses. I'll change them out and try again.
Thanks for the input.
  #203
Old 03-26-2010, 04:51 PM
Vipercliff's Avatar
Reverse lights
Ok. Changed fuses. I now have brake and blinker lights, However I don't have reverse lights. has anyone came across this one?
  #204
Old 03-26-2010, 04:57 PM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
Trade
i have smoke/red combination..anyone have the all clear version and want to trade?
  #205
Old 03-26-2010, 06:54 PM
jr1966's Avatar
jr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nice
The reverse lights aren't LEDs. The LED tails uses the exact same bulb & sockets the OEM tails use. If they worked before with the OEMs, they should work now with the LED tails. Something else may be wrong there....fuse, burned-out bulbs, wiring, corrosion in sockets, etc......
  #206
Old 03-26-2010, 07:13 PM
Vipercliff's Avatar
What fuse for revers light?
Does anyone know what fuse on the fuse panel goes to the reverse lights on a 99/996?
  #207
Old 03-26-2010, 10:02 PM
Frög's Avatar
Frög is infamous around these parts
Ok, I saw a 996 today with rice clear taillights.. Man, someone brought shame to this car, I was embarrassed to own one.
  #208
Old 03-27-2010, 01:03 AM
dynemd's Avatar
dynemd is infamous around these parts
Fuse to Backup Lights B5 (second row from the top, 5th fuse from the left)
7.5 amp. LINK CLICK
Old 03-27-2010, 07:24 AM
bavorak's Avatar
bavorak is a name known to allbavorak is a name known to allbavorak is a name known to allbavorak is a name known to allbavorak is a name known to allbavorak is a name known to all
Originally Posted by jstrat85
some pics of red and clear on my car. will post more pics later.
WOW, that looks great! Amazing how such a subtle change really improves the look of the 996 rear end. Very modern looking:-)
  #210
Old 03-28-2010, 08:25 AM
airedale's Avatar
airedale is infamous around these parts
Led all around.
Hello all,
I just received my new led tail lights in the mail. I was suprised there is no oem type pig tail on the new tail lights. Must I reuse the pigtail from the stock assembly? If so, is this reversible???
Do the new leds need to use some of the old oem parts?
For that money $500.00+-, I thought these tail lights would be 'plug and play'.
After reading the last 14 pages I am more confused than before.
Has anyone done a step-by step? With photos, diagrams, and schematics?
Thanks.
Quick Reply: LED Tail lights
