LED Tail lights
Edwin
I'm on the phone with the distributor. can you try this.... try the lights with the engine off but the key in position 2 in the ignition (last position before engine start)
Edwin
u might need an led relay, $5 from your local car parts store, i put them on mine when i just swapped out to led bulbs, at first they blinked real fast, then one i bought the led relay no prob since...hope that helps
edwin
engine off, #2, light off - normal flash rate
engine off, #2, lights on - fast flash rate
emergency falsh - normal flash rate with either lights on or off.
jorge
jorge
Sweet...thanks. Mine should come in monday. I hope they clear that blinking issue before I install it. Hopefully someone else will chime in with their experience. Mine has HID but I don't know why that would affect the blinking rate.
I have my smoked LED 3rd brake lights on the way too![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
Can't wait!!
Can't wait!!
Does any one know the size of the bolt off hand to remove the tail lamp? Any other tools or items I might need to install these babies? My lights came in but my car is at work. I was gonna bring the tools and lamps to work on monday and wanted to make sure I brought all the necessary tools.
