LED Tail lights
#31
Mine blinks fast also..I have an 02 with litronics. I know what you mean by the grommet now.
I was a little confused on which lights hooked up where on mine. Does anyone have an installation pic of where each factory harness goes and plugs into where? What did you do with the tiny factory bulb that is not suppose to be plugged in? Mine was not a perfect fit because one adapter had a 3 prong fit where the LED only had a 2 prong. I had to shave off the third prong. Anyone else have this issue?
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
#32
#33
Sorry for any inconvenience guys. I'm working on getting to the bottom of it. I'll let you all know what I find out (within a day or two)
Edwin
Edwin
#36
I'll try a heavyduty flasher later today.
jorge
#37
Just want to let everyone know that we want you to be satisfied and stand behind our GB. If we cannot get this issue fixed (or you simply do not want to deal with it), we will gladly refund your money back. Please give us a day or two to try to sort this out. Thanks
Edwin
Edwin
#42
Went to NAPA, they didn't have one, will have one tomorrow........more like $20 not $5. Thats ok though.
#43
It's a relay , it replaces the factory relay for ur flashers ,in your fuse box by the footwell, except it's made for LEDs , it says right On it led flasher, I remember only paying $5-$8 at most and that was only a few months ago , good luck let me know If it helps
