Coolant smell, then 2 days later i notice this. Please tell me this is not major.
Old 04-23-2009 | 04:26 PM
996SC's Avatar
996SC is infamous around these parts
Looks like you have the same problem I had right after Thanksgiving last year. I was driving home from work and pile of steam smoke coming from the back of my car when I stop at the light. I got home and look under the car and it was leaking directly under the water pump. At first I thought it was the expansion tank. After some investigating under the car, I realized the the leaking was coming directly at the shaft of the water pump pulley. I brought a waterpump in Ebay for ~$100 and replaced it following the writeup in Renntech.com (http://www.renntech.org/forums/index...howtopic=15737)! When I took the pump out I found one of the blade on the water pump fan broke off(not sure I cause it since I had to wiggle that thing out; it's pretty tight back there). Also when I spin the old pump, it was 3 or 4 time more resistance than the new replacement and it sounded awful. I guess the bearing and seal on the shaft was shoot and coolant was leaking out from there. You do need patients getting the pump out but after that it was pretty striaght forward putting everything back. That was 3500 miles ago and still running great -I think its even pick up some mpg after the change cause I was average 18.6 mpg ...now it's about 20 mpg with mix driving. Good luck!
Old 04-24-2009 | 12:57 PM
phaphaphooey's Avatar
phaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond repute
Pelican is nice but they are usually more expensive than suncoast/sunset.
audipwr1
09-25-2021 01:31 PM
mikerosi
12-06-2018 06:23 PM
viprklr
05-23-2018 11:33 AM
LiquidElephant
08-27-2015 06:17 PM
gulf gt
08-27-2015 10:27 AM
Quick Reply: Coolant smell, then 2 days later i notice this. Please tell me this is not major.
